Activity Forums Avid Media Composer Windows XP Home Edition?
  • Windows XP Home Edition?
    Posted by Rob Roams on June 1, 2007 at 12:36 pm
    Will Media Composer software only, version 2.5.3, preform well with Windows XP Home Edition with SP2? Or do I need to buy Windows Professional?
    Pentium D Intel Dual-Core 3.6GHz
    2GB of RAM
    Thank you
    Rhewitt replied 19 years, 3 months ago 3 Members · 2 Replies
  • Jon Zanone
    June 1, 2007 at 1:43 pm
    You’ll need professional to avoid headaches. Using XP home has caused all sorts of problems with the Avid software.
    Jon
  • Rhewitt
    June 6, 2007 at 11:39 pm
    Windows XP Home is not supported for any version of Media Composer. See required specs below:
    Media Composer – Windows
    Windows XP Professional with Service Pack 2
    System memory: 2 GB minimum, 3 GB recommended for HD or high stream count SD projects.
    CPU: Dual 3.06 GHz Xeon
