Windows Vista 64Bit Ultimate & 4D
My old 3.2ghz HT XP system is going to the retirement home after yet another failed monitor. Since it is out of warranty, I did a bit of research and read an article about how well Cinema 4D runs on AMD 64 bit with Windows 64 bit Ultimate. So I shelled out the money for the AMD 64 Bit Dual Core and Windows Vista Ultimate 64 bit…. and guess what? Cinema 4D doesn’t run on it at ALL! 32 bit nor 64 bit!!!
Much to my surprise, after installing it and entering my serials, it complains about not being able to write a file called “coffee” due to i being busy or write-protected. Actually, the file it is trying to write doesn’t even exist, and the directory is wide open for read/write. So, I have to enter the serials into the 64 bit version every single time. The 32 bit version took the serials just fine, but cannot process even a simple spline.
In my system, it actually seems to have something to do with the NVidia driver, and I did some research to find that there are thousands of folks, mostly in gaming forums, having trouble with 3D video drivers and Windows Vista. At first, my search was just about the NVidia driver but I came across some people having trouble with their ATI drivers and vista.
So, does anyone have a solution? I can run After Effects just fine (so far), and my other graphics programs. It seems to vomit at 3D. I honestly don’t think it is Cinema 4D (except the 64 bit version not saving the serials). I think it has something to do with Vista and 3D Graphic rendering. However, since I’m using 4D… if anyone has the tweak, then I’d sure like to hear it.
Things I’ve done:
1) Ran a memory scan to ensure my memory is working OK.
2) Ran a heat check to ensure my computer isn’t heating up.
3) Made sure I have enough disk space (145GB of it free)
4) Ensured I have the latest drivers
5) Registered Cinema 4D into the NVidia driver (but it doesn’t keep the profile for some reason).System Configuration (good enough for what I do and can afford, so you Voodoo guys leave me alone 🙂 )
HP Pavillion 9000z (customized)
AMD Turion Dual Core 64Bit 2.2GHz
Windows Vista Ultimate 64Bit version
SVGA+ graphics
NVidia 6500 GO (I know, I know)
2GB Ram (I know, I know)
240GB HDI use this laptop machine for general design and assembly, texture creation, etc. I then use a desktop for rendering. The thing is, the desktop is an AMD Athalon 64Bit machine running Windows XP 32 bit, and 4D cranks away with no problems.
Any help, advice, general research, or location of a witch doctor would be appreciated.
Joseph M Morgan
