Activity Forums Blackmagic Design Windows v6 drivers – audio delayed
  • Windows v6 drivers – audio delayed
    Posted by Jim Atkins on March 20, 2007 at 9:56 am
    Is anyone else having this problem, or am I just lucky? When I capture using the Decklink utility, the embedded audio over SDI is captured one frame in advance of the video.
    NTSC/8bits/BM codec.
    Uncompressed to a QuickTime file.
    Decklink Pro.
    XP Pro SP2, latest updates.
    QuickTime 7.1.3
    Thanks.
    Jim Atkins replied 19 years, 6 months ago 1 Member · 1 Reply
  • Jim Atkins
    March 20, 2007 at 12:33 pm
    I installed v4.8.1 drivers as a test, and the audio was delayed by three quarters of a frame. Going back to v6 reset the delay to one frame. In both cases the delay was consistent and repeatable.
    I tried two other manufacturers cards, and both functioned correctly in the same chain. The CPU is an HP xw8200 that was used for over a year capturing HD without issue (using another brand of card).
