Activity Forums Adobe Premiere Pro Windows 7 and Adobe Premiere Pro CS4
  • Windows 7 and Adobe Premiere Pro CS4
    Posted by Paul Dankers on January 28, 2010 at 12:30 am
    A couple of months ago, I updated from Windows XP pro with Adobe Premiere Pro CS3 to Windows 7 Enterprise 32 bit with Adobe Premiere Pro CS4. I built a brand new machine with an i7 processor and 6 GB of memory. I have had more glitches since I made the switch than Windows ME. Here are some examples:
    #1. I created a long and complicated sequence. When I send it to the Media Encoder, I always get an “unknown error.” I’ve tried different encoding settings, nothing makes any difference. But… When I take it apart and render the parts individually, ALL of them will render without a problem.
    #2. I tried converting all of the video to AVI and recreating the sequence. This time, the entire sequence rendered (it took the better part of a week–about 80 hours) and when it was finished, the video galloped along at several times the normal speed and then hung on the last frame. Meanwhile, the sound was normal.
    #3. I tried creating a DVD with the invidual parts that I rendered and I discovered that the rendered video had video and audio tracks that were of different length, so that when I tried to compile the play list, I ended up with a video that was considerably shorter than the audio.
    #4. I bought the Dolby 5.1 codec and if I do not multiplex the video and audio together, the surround sound doesn’t show up at all.
    #5. If I do multiplex the video, the audio track ends up being about 3 or 4 times longer than the video track.
    #6. I am having trouble importing rendered video into Encore. When I try to import the video as an asset, the whole computer locks up and I have to do a hard restart.
    #7. I have tried contacting customer support, but I can only get ahold of their lowest level support, which apparently is outsourced to India. They have escalated my case, but nobody has responded or called me in almost 2 weeks. It has been a month and counting since I began asking for help with these glitches. Does anybody know how to reach anybody from Adobe in the USA?
    I have tried everything that I can think of. I have updated all of the drivers, firmware, Windows, & Adobe. I just keep finding more and more glitches. Is anybody else having these problems? Does anybody have any suggestions?
    James Barr replied 16 years, 7 months ago 5 Members · 5 Replies
  • Mike Velte
    January 28, 2010 at 11:45 am
    What format is your source video? What is the source?
  • James Barr
    January 28, 2010 at 5:11 pm
    Part of your problem might be that you’re only using 3GB of your RAM. You need to use a 64-bit operating system to use more than 3GB of RAM, so go buy a copy of Windows 7 x64.
  • Hector Melendez
    January 29, 2010 at 3:59 pm
    “Part of your problem might be that you’re only using 3GB of your RAM. You need to use a 64-bit operating system to use more than 3GB of RA”
    Not necessarily. I have a desktop with 3meg of ram 32-bits and CC4 runs well. Whats over, the same CC4 is installed in a Laptop with Windows 7 home 64bits, a 500g HD, 4gigs ram & ati 512mb video card (it passed ok the installation requirements) and Premiere freezes constantly, inclusive does not permit to save the job and lots of others interferences. So I concluded is W-7 the problem.
    Thinking to downgrade to XP in the laptop!!
  • Brian Louis
    January 30, 2010 at 4:45 pm
    [Hector Melendez] “a 500g HD”
    This the only Harddrive in your system? You should have a separate dedicated drive for video files, using the same drive as the OS and apps can have problems even with separate partitions.
  • James Barr
    February 1, 2010 at 9:41 pm
    Aye, hard drives are so underrated when it comes to video editing by most people. You’re not going to gain hardly anything by going to XP; and maybe nothing whatsoever.
