windows 7 64 bit configuration guide video editing pc
Posted by Thayalan Paramasawam on February 19, 2014 at 10:46 amHi Everyone,
my new AMD FX 8350 is to slow,its could be window updates because i always update the window.so now i format back machine and update the window once only.
Is there any configuration must do for window 7 64bit so its only utilize for video editing only especially for SVP 12?
Thannk You
Thayalan ParamasawamSystem Details:
Custom Built
Working Station 1) – Motherboard – Asus M4A78 Plus,Processor – Amd Phenom llx4 945 Black Edition,Ram – 4GB,Graphic Card – Ati Radeon HD 5990,Dvd Writer – Plextor PX-890SA,Operating system – Window 7 Pro 32 bit and Editing Programe -Sony Vegas Pro 10Working Station 2) – Motherboard – Asus M4A88T-V-EVO Series,Processor – Amd Phenom llx4 955 3.2GHZ Black Edition,Ram – 16 GB,Graphic Card – Asus HD 6770 1GB DDR 5,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 11
Working Station 3) – Motherboard – Asus M5A99X-EVO,Processor – Amd FX 8350 4.0/4.2 GHZ,Ram – 16 GB,Graphic Card – Asus Gtx 650 1GB DDR 5,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 12
Abhi Nash replied 12 years, 7 months ago 5 Members · 19 Replies -
Dave Osbun
February 19, 2014 at 2:01 pmYou say your AMD-powered system is too slow. Too slow doing what? On boot-up? During renders? If it’s regarding render speed, all the CPU tests i’ve seen on Tom’s Hardware and AnandTech have shown the AMD processors to not really be that good for video edit workstations.
Unfortunately there’s not really anything you can do except maybe overclock the CPU, but I would not really recommend doing that.
What type of system drive(s) are you using? You didn’t state this in your post. Are you using SSD or ‘regular’ hard drives?
From AnandTech’s website:
https://www.anandtech.com/bench/CPU/27Dave
February 19, 2014 at 3:08 pmhi sir,
1)(During renders?)….yes during rendering
2)(What type of system drive(s) are you using? You didn’t state this in your post. Are you using SSD or ‘regular’ hard drives)…..this is my spec
Working Station 3) – Motherboard – Asus M5A99X-EVO,Processor – Amd FX 8350 4.0/4.2 GHZ,Boot (system c) – SSD Kingston,Ram – 16 GB,Graphic Card – Asus Gtx 650 1GB DDR 5,Hard Disk (Storage) – WD Black,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 12
System Details:
Custom Built
Abhi Nash
February 19, 2014 at 5:24 pmYou can’t expect renders to be super fast!
It has it’s own pros and cons.The project you might be rendering may have a ton load of effects,which will in-turn slow your PC down.Since you have a Cuda GPU,in the render windows of Vegas Pro 12,select “Render using GPU” this will speed up your render as Vegas will use your GPUs’ Cuda Cores.
Abhi Nash
Editor,Colorist,Compositor
AMD FX 9590
8 GB RAM
Nvidia GT640 -
Stephen Mann
February 19, 2014 at 10:53 pm -
February 20, 2014 at 12:00 amits crash when my gpu acceleration on when rendering mpeg 2 for dvd
System Details:
Custom Built
February 20, 2014 at 12:04 am(Stephen Mann)CUDA is nVidia. AMD cards use OpenCL.
I am using gtx 650 because my motherboard support nvidia cards.
System Details:
Custom Built
Stephen Mann
February 20, 2014 at 3:07 amI’m not sure which workstation you are working with on this issue. You listed ATI graphics, but do you have both ATI and nVidia on the same PC?
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Abhi Nash
February 20, 2014 at 4:13 amWhat do you mean by Crashes when you turn on GPU Acceleration?
Well,if Render times are too long for SVP 12,Why not work in SVP 11?There are only minor updates. -
February 20, 2014 at 5:49 amHi Sir,
(Stephen Mann)I’m not sure which workstation you are working with on this issue. You listed ATI graphics, but do you have both ATI and nVidia on the same PC?
This is my spec
System Details:
Motherboard – Asus M5A99X-EVO,HardDrive1 boot C:SSD Kingston,Processor – Amd FX 8350 4.0/4.2 GHZ,Ram – 16 GB,Graphic Card – Asus Gtx 650 1GB DDR 5,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 12…….System Details:
Custom Built
Motherboard – Asus M5A99X-EVO,HardDrive1 boot C:SSD Kingston,Processor – Amd FX 8350 4.0/4.2 GHZ,Ram – 16 GB,Graphic Card – Asus Gtx 650 1GB DDR 5,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 12 -
February 20, 2014 at 10:04 am(Abhi Nash)What do you mean by Crashes when you turn on GPU Acceleration?
It will stop rendering or not responding after few minutes…..
(Abhi Nash)Well,if Render times are too long for SVP 12,Why not work in SVP 11?There are only minor updates.
Yes i am SVP 10,SVP 11 and SVP 12 in differend working station.So in my case i try to solve the probleum by discuss with the professionals in this forum so the SVP 12 can improved.
Thank You
Custom Built
