Activity › Forums › VEGAS Pro › windows 7 64 bit configuration guide video editing pc
  • Abhi Nash
    February 20, 2014 at 1:57 pm
    Download a new update a patch maybe for SVP 12?
  • Stephen Mann
    February 20, 2014 at 2:02 pm
    “its crash when my gpu acceleration on when rendering mpeg 2 for dvd”
    GPU will help with some CODECS, notably AVCHD. There is NO GPU acceleration for MPEG or AVI.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Thayalan Paramasawam
    February 20, 2014 at 10:26 pm
    Hi Sir,
    (Stephen Mann)GPU will help with some CODECS, notably AVCHD. There is NO GPU acceleration for MPEG or AVI.
    Then whats the probleum could be?
    Thank you
    System Details:
    Custom Built
    Motherboard – Asus M5A99X-EVO,HardDrive1 boot C:SSD Kingston,Processor – Amd FX 8350 4.0/4.2 GHZ,Ram – 16 GB,Graphic Card – Asus Gtx 650 1GB DDR 5,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 12
    February 21, 2014 at 1:13 am
    Hi…..
    (Abhi NashDownload)a new update a patch maybe for SVP 12?
    I use the latest version 12.0 (Build 770)
    System Details:
    Custom Built
  • Nigel O’neill
    February 21, 2014 at 2:32 am
    [Thayalan Paramasawam] “System Details:
    Custom Built”
    Thayalan, you do not mention any hard drives or SSD in any of your system configurations. I would certainly use an SSD for the boot drive C:, and perhaps use 2 pairs (total of 4) of Western Digital 10,000 RPM VelociRaptor drives in a mirror and stripe configuration. This assumes your motherboard supports hardware RAID and can handle that many SATA connections (I count you would need 6). You could just get by with 2 VelociRaptor drives and not worry about redundancy and instead rely on regular backups to a USB 3 drive. You would most likely need to use a 1000W power supply.
    I have used VelociRaptor drives and they do run quite hot, so good case cooling is essential.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Abhi Nash
    February 21, 2014 at 6:18 am
    Maybe you’re experiencing render times like every one of us.
    Or,you maybe working with a different codec,you haven’t mentioned the type of footage that you’re working with.
    February 22, 2014 at 1:15 am
    (Abhi Nash)you haven’t mentioned the type of footage that you’re working with.
    AVCHD (1920X1080 50P)
    System Details:
    Custom Built
    February 22, 2014 at 1:21 am
    (Nigel O’Neill)you do not mention any hard drives or SSD in any of your system configurations.
    I am using SSD for the boot drive C
    System Details:
    Custom Built
  • Abhi Nash
    February 22, 2014 at 5:28 pm
    HD should take a fair amount of time to render.
Page 2 of 2
