Activity › Forums › Blackmagic Design › Windows 6.0 Drivers are up
Posted by Peter Corbett on March 9, 2007 at 11:04 pmThe Windows 6.0 Decklink drivers are up on the Decklink site.
Peter
Peter Corbett
Powerhouse Productions
http://www.php.com.auDeleted User replied 19 years, 6 months ago 5 Members · 18 Replies -
Peter Corbett
March 9, 2007 at 11:27 pmNew features look cool for 6.0.
* Windows Vista 32 bit support
Peter Corbett
March 9, 2007 at 11:39 pmSorry, me again. Wow, I’m getting RT downconverted playback of uncompressed 10-bit HD and also real time downconverted playback of native HDV files in an uncompressed project without rendering. I’m using a HD Extreme with YUV monitoring on a 14″ component standard-def monitor.
This is quite a leap. Well done BM guys!
Peter
Peter Corbett
http://www.php.com.au -
Peter Corbett
March 10, 2007 at 12:17 amTried installing 6.0 on my Vista 32 system but although the software and drivers install, the Decklink display does not appear in the Device Manager or graphics display properties. And the RS422 serial and audio drivers won’t install. XP SP2 works fine.
I have a 8800 GTS VGA and Audigy 4 Pro sound card. Both have the latest Vista drivers installed. The mobo is a Supermicro X7DA8. Any clues Kristian?
Peter
Peter Corbett
Wolf
March 10, 2007 at 7:57 amHi,
when i capture DV PAL video via firewire, the clips are field inverted in the timeline.
Am i the only one?
Claus-Peter Wolf
Peter Corbett
March 10, 2007 at 12:20 pmI’ve installed, uninstalled and reinstalled 6.0 drivers several times on a standard Vista 32 installationw without success. The BM display does not appear in Device Manager or Display Properties.
Peter
Peter Corbett
Deleted User
March 11, 2007 at 12:08 pmHello,
I installed Vista Ultimate 32bit clena install, I set al the updates and then installed Adobe production Studio 2.0. I then installed all the new Adobe updates.
I then run the Multibridge 6.0 drivers for Vista support.
The errors I am getting are as follows;
1). ck on the Multibridge configuration screen to get to the controls for DVI etc. I get an error message “Deckcp.exe – Unable to locate component”
This application has failed to start because MFC71U.DLL was not found. Re-installing this application may fix this problem.
2.) I try and play any music or sound from Widows Media Player and I am getting an underwater sound and the audio sounds choppy and stuttering effect/sound.
3.) I lauch a BMD project pre-set from Adobe Premeire Pro 2.0, such as a BMD-DV project I set the preferances of the Audio channels to map to Decklink. I get no VU levels and no sound comes out of my speakers. The sound is connected to the Multibridge Extreme Pci-e from the analogu RCA outs to a mixer then speakers.
If I change the preferances to the on board Premeire Prosound then the VU meters in Premiere pro 2.0 alter and display but still no sounds.
4.) I am not getting the display graphics card listing as Blackmagic for the extended view. Either in device manager or display settings.
Anyone had similar problems?
Peter Corbett
March 11, 2007 at 6:24 pm[Leo Baker] “The errors I am getting are as follows;
Anyone had similar problems?”
I’m on Decklink HD Extreme Leo. Even though BM have released Vista drivers, there are possible problems with running the whole Production Suite on Vista. Check the official Adobe forums for more info;
https://www.adobeforums.com/cgi-bin/webx/.3bbdfa9a/?@634.r3e6g4U84ir@
I can’t get the Decklink to appear in the display properties and I’ve tried everything. Also having problems with RS422 and Audio components of Decklink on Vista 32. Are we the QA component here?
Peter
Peter Corbett
Deleted User
March 11, 2007 at 7:02 pmHello,
Yes I tested Adobe Poductin Studio 2.0 on Vista Business w few weeks ago and everything semeed fine except for the Multibridge where the graphics card of the mUltibridge would be disabled and audio lagging underwater effects which I am still getting now with the Multibridge Extreme. But everything worked okay in Production Studio 2.0 from what I saw stand alone.
Hope the Vista drivers from Multibridge Extreme and the other models work. Also any bugs and fixs Adobe should hurry up as they have made Vista updates for the low end; Photoshop and Premeire elements.
Leo
Manololp
March 11, 2007 at 7:04 pmNo, I am too. This is very annoying. If driver version 5.7.3 is Ok, why 6.0 is not?
Deleted User
March 14, 2007 at 12:04 pmHello,
I tried everything Blackmagic Support said I updated the shipset drivers which controls how the blackmagic software installs and still have these problems. I am just going to go back to Windows XP and steer clear of Vista I will just sell the Vista DVD to a friend etc as I paid
