Activity Forums Blackmagic Design Windows 4.8.1 – How to know if driver is installed correctly?
  • Windows 4.8.1 – How to know if driver is installed correctly?
    Posted by Content Lab on May 24, 2005 at 7:15 pm
    Hello,
    WinXP DeckLink HD Pro Single Channel user here. I believe I just updated to the 4.8.1 drivers. However I’m conflicted because when I look at my Device Manager->Display Adapters->Blackmagic DeckLink Display properties it stll says I’m on driver version 4.7.0.0
    I just updated this morning by downloading the update driver from this link:
    https://www.blackmagic-design.com/downloads/software/DeckLink_Windows_v4.8.1.zip
    Opening the zip file gives me the following file:
    DeckLink_Windows_v4.8.1.msi
    When I opened it I initially chose to “Repair Blackmagic DeckLink” and it went through the motions and completed ok but after a restart I still saw 4.7 in the driver properties of my Device Manager.
    So I tried again this time I chose to “Remove Blackmagic DeckLink” and then opened the msi app again to install the drivers. After a restart my Device Manager properties still shows version 4.7. However I do see version 4.8.1 in the readme file.
    How do I check to make sure I’m really running the latest drivers?
    Jaromir Pesr replied 21 years, 4 months ago 3 Members · 2 Replies
  • Barend Onneweer
    May 25, 2005 at 6:30 pm
    When you update a driver, make sure you first uninstall the old one (using the Add/Remove Software function in the Control Panel) before you install the new driver. It sounds like you’re still running the old driver. Best to remove all Decklink drivers now, and then install the latest ones.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Jaromir Pesr
    May 26, 2005 at 2:00 pm
    Hi
    I’ve just installed fresh new XP system and finaly 4.8.1 Decklink drivers. After reading this thread I’ve looked to device manager and surprisingly the drivers shows 4.7. Strange…
    Jaromir Pesr
    IO postproduction
    Prague, Czech Republic
