Activity Forums Adobe After Effects Wind Gust Effect
  • Wind Gust Effect
    Posted by Ben Sturgulewski on June 23, 2008 at 1:56 am
    I have some head-on wide footage of a man standing in desert field full of yellow straw/grass about a foot high. I’m compositing a large object swinging down in an arc from the left to the right, and almost hitting him (he falls to the ground to avoid it)– like a wrecking ball. I want this ball to create a gust of wind through the grass as it goes by, and then once it has passed out of frame, have the grass slowly go back to its windless state.
    I’ve read some threads about how to do the wind effect, basically by creating displacement maps and perhaps using the wiggler to skew out the horizontal/vertical displacement. I made a displacement map off of a radial ramp and made it track the object to follow behind it as it crosses the screen… then I masked off the area I want affected by the wind, feathered it a lot, and applied the map. This looks like it will work once it is well-tweaked. It creates the beginning of the wind effect, however, since it is just a circle the map is over to quickly and the grass returns to its normal position too quickly–it looks unnatural. Ideally I suppose the map I would want would look a “comet”, I guess… total black to almost total white at the rightmost side then slowly tapering off on the left to produce the effect of the wind slowly dying out. It seems like that would work. Any idea how I would produce this map, or of any other way to make the effect look more realistic?
    I also have two other questions while I’m here (I’m new to displacement maps). When the map tracks too far to the right of the screen, whatever is cut off wraps around and comes out of left frame. How do I extend it so this doesn’t occur?
    This last one is really confusing me… about the time the object first comes onscreen, the grass suddenly starts to become displaced, even though the map has not reached those pixels yet– that area is still fully black on the map. They only become slightly displaced, however. When the actual map comes through they become extremely displaced as expected, but I have no idea why its displacing before the map gets there? All compositions and the ramp layer are the same dimension. Sorry for all the questions but I have much to learn. Much thanks.
    Ben Sturgulewski replied 18 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
