Activity Forums Adobe After Effects Wind being sucked into a sword
  • Wind being sucked into a sword
    Posted by Jordan Norman on July 4, 2009 at 3:13 pm
    I have created a solid layer and added fractal noise to it to give a wind effect. I now need this wind to be sucked into and object. For an example of what i’m trying to achieve look at 4:52 of this video. Click here for video
    Cheers, Jordan
    Tom Scott replied 17 years, 2 months ago 3 Members · 2 Replies
  • Kevin Camp
    July 6, 2009 at 1:37 pm
    i’m not in front of ae at the moment, you might give cc flow motion a try… it will create a sucking-into-a-pont-like distortion. a
    also, bulge with negative values will start to do a similar effect and mesh warp could be manipulated to create that too.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Tom Scott
    July 7, 2009 at 2:05 am
    Maybe you could use some of the techniques used in this tutorial.
    DISCLAIMER: The contents of this post are based primarily on the opinions/understanding of the author. However, commonly known facts may also be included, when relevant.
