Activity › Forums › Storage & Archiving › Win 7 go from 1 disk no raid to 2 disk raid1 w/o re-install?
  • Win 7 go from 1 disk no raid to 2 disk raid1 w/o re-install?
    Posted by Bob Sacramento on August 29, 2011 at 3:49 pm
    Is it possible to go from 1 hard drive to RAID 1 (add another hard drive) without formatting?
    I have a Windows 7 desktop system with OCZ 120GB SSD drive and I have added 1TB drive for Data storage ( movies/music/pictures).
    I keep having to back up my pictures and movies and I wish I had set up my system as 2x 1TB drives with Raid 1 config.
    Now I actually want to do this… but I don’t want to start fresh and re-install everything. Can I just add 1 more 1TB drive and set up the system as Raid 1 ? or is it absolutely necessary to do a clean install ?
    My motherboard is p67 chip and it supports Raid 0-1-5-10.
    Here is my desktop specs if you need it:
    GIGABYTE GA-P67A-UD3-B3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard with USB3.0 and supports 2nd gen i5 chip https://www.gigabyte.com/products/p […] id=3765#ov
    Latest Intel 2nd generation i5 2500k “unlocked” 3.30GHz (auto overclocks to 3.7)
    ARCTIC COOLING Freezer 7 Pro Rev.2 92mm
    ADATA 8GB PC1600 DDR3 ram (altho the mobo and cpu hold the ram to 1333)
    OCZ 120GB SSD SATA 3.0GBs solid state drive 250MBps read 250MBps write
    Samsung 1TB SATA 3.0GBs 7200rpm internal drive
    (Will add 1 more Samsung 1TB Sata drive to make raid 1)
    Asus 24X dvd burner
    OCZ ModXStream Pro OCZ500MXSP 500W
    Antec P183 case w upper/lower chamber. 11 expansion bays. great air flow
    Windows 7 x64
    Fred Jodry replied 15 years ago 4 Members · 16 Replies
  • 16 Replies
  • David Roth weiss
    August 29, 2011 at 4:35 pm
    [Bob Sacramento] “Is it possible to go from 1 hard drive to RAID 1 (add another hard drive) without formatting? “
    No!
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new tutorial: Prepare for a seamless transition to FCP X and OS X Lion
    https://library.creativecow.net/weiss_roth_david/FCP-10-MAC-Lion/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Todd Perchert
    August 29, 2011 at 5:29 pm
    No, but you don’t need to do a clean install. You have 2 controllers on that mobo. Backup your files, because you will need to format your 1TB data drive – any data on it will be wiped out. Place the SSD on the SATA 6G, place the 2x1TB drives on the other SATA (3g) controller. You’ll probably need to go into the BIOS and tell it to set that controller to RAID. You should then be able to create the array from the controller BIOS when booting up, or software after you boot up.
    If you’re not sure about anything, get someone who knows what they are doing to help or pay. Reading the manual will help as well.
    Good Luck!
    TC
  • Bob Sacramento
    August 30, 2011 at 4:33 pm
    i made an external copy of the data on the 2nd disk.
    then i set the the PCH SATA Control Mode to be RAID in BIOS.
    then i rebooted and i saw a new raid configuration menu that you can open with CTRL+I.
    i entered it and i configured raid for port 4 and port 5 of my 2 disks to be RAID 1. (Ports 0&1 are sata3, ports 2,3,4,5 are sata2).
    then i exited and rebooted. upon reboot, it tries to load windows.. shows the logo screen for a second.. then blue screen for a split second and then just dies and restarts.
    i noticed during bios post and when it prints the disks and its rain info. it shows my port 0 (SSD) drive is also using raid driver.
    it also said ACHI driver not installed.
    then it lists all my drives
    then it tries to load windows and fails.
    Any idea what I’m doing wrong here?
  • Todd Perchert
    August 30, 2011 at 4:50 pm
    Sounds like it could be using all the SATA ports in the RAID. Should be able to switch back to non-RAID and boot up. But make sure first that it is indeed set in BIOS to try booting from that SSD drive before any other drives.
    But, and I just thought of this… when selecting the RAID in the BIOS, it may have switched your port with the SSD drive to AHCI, try changing that to IDE.
    TC
  • Bob Sacramento
    August 30, 2011 at 7:08 pm
    so changing to RAID def sets it to use AHCI.
    I reset my raids to non-raid.
    set the controller to be IDE
    restarted and was able to get into windows.
    i looked up installing AHCI on my motherboard, i downloaded the install and read the install instructions, it says to hit F6 during windows install to install ahci drivers.. but i already have a system.
    anyway i rebooted the machine and set the controller to be AHCI.
    Now when i boot it says that AHCI is installed. … i havnt installed anything though..so I’m confused there
    https://www.gigabyte.com/products/product-page.aspx?pid=3765#dl
    SATA RAID Version Size Date Download Here
    Intel SATA Preinstall driver
    (For AHCI / RAID Mode)
    Note: Press F6 during Windows setup to read from floppy.
    10.6.0.1002 0.39 MB 2011/06/22 Asia China America Europe Europe(Russia) : FTP / Http
  • Bob Sacramento
    August 30, 2011 at 7:52 pm
    okay i am closer to solving it.
    i found this while googling the fact that i had blue screen of death when switching from IDE to AHCI
    https://www.tomshardware.com/forum/244840-32-convert-sata-ahci-vista
    that pointed me to the microsoft KB article
    https://support.microsoft.com/kb/922976
    which told me to modify registry
    To resolve this issue yourself, enable the AHCI driver in the registry before you change the SATA mode of the boot drive. To do this, follow these steps:
    Exit all Windows-based programs.
    Click Start, type regedit in the Start Search box, and then press ENTER.
    If you receive the User Account Control dialog box, click Continue.
    Locate and then click one of the following registry subkeys:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Msahci
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\IastorV
    In the right pane, right-click Start in the Name column, and then click Modify.
    In the Value data box, type 0, and then click OK.
    On the File menu, click Exit to close Registry Editor.
    so I set the controller back to IDE, was able to get into windows
    then i chagned the registry
    then i rebooted and changed controller back to AHCI
    then i was able to boot into Windows!
    Now what i am doing is… installed IRST Intel Rapid Storage Technology, which is a prereq to having ahci drivers for my motherboard.
    It still failed when set to use RAID.
    I then googled more and found this.. if you scroll to bottom a guy has 3 screens up
    https://forums.tweaktown.com/gigabyte/40484-ahci-bios-not-installed.html
    Anyway i realized it says SATA native enabled for Ports 0-3. .. so maybe using ports 4&5 aren’t such good idea.
    So i put the drives to ports 2 &3.
    Then it still failed.
    I went to bios and set CMOS to factory
    I updated my bios with q flash from the bios menu with a usb stick.
    then i set it to optimized.
    then i set it to raid
    then i rebooted and set my raid configuration to non disk, then again set it up for 2 disks.
    then rebooted.
    still windows crashes right when i see logo screen..
  • Todd Perchert
    August 30, 2011 at 10:58 pm
    You may want to go back to where it worked. Should be able to software RAID those drives if anything. You may want to check with Gigabyte as to why it crashes when changing to AHCI. I had to change from IDE to AHCI before on a EVGA board, the process was a whole lot smoother…
  • Bob Sacramento
    August 31, 2011 at 4:21 am
    Actually I am able to set the PCH Controller to AHCI now..
    what i did was to insert the CD-ROM that came with the gigabyte motherboard and did express install of all the chipsets.
    Now I can have all the drives connected and set the controller to AHCI.
    On BIOS POST , i see it says AHCI BIOS installed now.
    But as soon as I change the controller to RAID and enter the Raid configuration utility and create my 2 disks to be Raid… upon reboot it says AHCI BIOS not installed, and crashes when windows tries to boot
    I am wondering if it is at all possible to have a system where 1 disk is used as the System disk and is NON RAID, and have 2 other disks to be set to RAID, which will be used for Data like pictures/music/movies.
    Maybe its simple not possible to have a raid system where the main OS is not installed on a raid, but only the ‘slave’ drives are set to RAID.
    Or am i wrong?
  • Bob Sacramento
    August 31, 2011 at 5:18 am
    this is kind of related to the above post, but from all my reading in the “Intel® Rapid Storage Technology” read me that i got from the gigabyte motherboard page, it seems like they want you to install the Raid controller/driver during Windows install.
    So perhaps, you cannot start with a system that has Windows 7 already installed and try to setup raid on 2 other disks…
    In my scenario, i am starting out with an install of windows 7 on ssd and adding 2 disks to be raid.
    I think what the documentation wants me to do is install WIndows 7 and install raid controller right before windows 7 starts to install…
  • Bob Sacramento
    August 31, 2011 at 1:47 pm
    I think I know why my OS is crashing…
    I can get my OS to boot and all my disks to show up in AHCI mode..
    But as soon as I set PCH Controller = RAID… it tries to boot ALL the drives with RAID controller, which makes sense why my OS would then crash.
    I’ll paste a screenshot here so you can see what the printout is from BIOS POST of all the drives when in RAID mode
    https://img703.imageshack.us/img703/2638/photo5q.png
    I dont know where the settings live for setting the controller “per drive” or if its possible. Here is snapshot of choices in BIOS where I do set it… but it applies to ALL drives. You can see my choices are IDE/RAID/AHCI.
    https://img163.imageshack.us/img163/8788/photo2y.png
    Here is snapshot of when AHCI is enabled, and you can see all the drives post, then windows loads fine shortly after.
    https://img820.imageshack.us/img820/9656/photo1y.png
    Here is the snapshot of the Integrated Peripherals screen, you can see I set PCH Sata Control Mode to RAID, but its not per drive.. i think it affects all drives. I also have Sata Port0-3 Native Mode Enabled
    https://img202.imageshack.us/img202/1757/photo3n.png
    Here’s screen shot of the Hard Disk Boot Priority
    https://img854.imageshack.us/img854/9633/photo4m.png
    So I guess the main thing for me is to try and figure out how to get my OS to load in AHCI, while having the other drives load with RAID Controller…
    The problem is I havnt been able to find a Per Drive controller setting.
    I want my system to be like so…
    * 120GB SSD non-RAID (run by AHCI controller) (Windows7 is installed here)
    * 1TB Samsung drive RAID-1 (run by RAID controller) (used only for data, pictures/movies)
    * 1TB Samsung drive RAID-1 (run by RAID controller)(used only for data, pictures/movies)
    and what is happening is that when i set my PCH Sata Control to be AHCI, ALL disks are run by AHCI controller and everythings works and windows loads.
    and when i set my PCH Sata Control to be RAID, ALL disks are run by RAID controller and it tries to boot my OS by RAID controller and fails! This is because i never initially set my controller to be raid when installing Windows 7.
    Any ideas?
