Activity › Forums › Apple Final Cut Pro Legacy › will Multicam editing using a XH-A1 and and F300 be possible
  • will Multicam editing using a XH-A1 and and F300 be possible
    Posted by Jan Bliddal on October 20, 2010 at 9:47 am
    If the XH-A1 is set to 25F and the F300 uses the 1440×1080 25P setting and transcoding both to ProRes on Ingest before adding them to the Multicam time line?
    Or will you suggest getting a XH-A1s to best match my current XH-A1 and adding FS-CF Pro Portable Compact Flash DTE Recorder to them if I want more than 1 our of record time filming presentations that goes beyond the 1 hour HDV tape maximum?
    Let the machine work for you. Not you for the machine
    Jan Bliddal replied 15 years, 11 months ago 2 Members · 2 Replies
  • Mark Petereit
    October 20, 2010 at 12:23 pm
    All the clips must use the same codec, image dimensions, and frame rate.
  • Jan Bliddal
    October 20, 2010 at 3:29 pm
    Hi Mark I am aware of that part I am however not sure about 1440x1080F 25F beeing equal to 1440×1080 25P in the eyes of ProRes. I really would like the F300 do to its 50mbit 4.2.2 codec, but I would like to be able use it with my existing AH-XH1 camcorder in a multicame setup. And I am wondering if Canons HDV 1440×1080 25F and canons 1440×1080 25P format will match when transcoded through ProRez. I mean framesize is the same. framerate is the same I am just woundering if the F for Full is to different from the P as in Progressive
