Activity Forums Apple Final Cut Pro Legacy Will FCP6 open FCP3
  • Will FCP6 open FCP3
    Posted by Brian Klein on February 25, 2008 at 4:47 pm
    I’m trying to open a FCP 3 file in FCP 6, but I keep getting the message: “Unable to open project file.” Should FCP 6 be able to open FCP 3 files. Could the file be getting corrupted somehow?
    Thanks for your help!
    Brian Klein replied 18 years, 7 months ago 2 Members · 3 Replies
  • Arnie Schlissel
    February 25, 2008 at 9:11 pm
    It’s very possible that the file is corrupted. Where did it come from? How was it brought to you? If it was emailed to you, this is a common problem. Have the client make a zip archive of the file & email it to you again.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Brian Klein
    February 26, 2008 at 3:08 pm
    It was brought to me via firewire drive… after some investigation, I found out it is a MS-DOS formatted drive. I’m assuming this is probably where the problem is?
  • Brian Klein
    February 29, 2008 at 5:02 pm
    Apparently the MS-DOS drive was the problem… I reformatted the drive to MAC OS Extended, and had them recopy FCP project onto the newly formatted drive, and everything is now good to go.
