Activity Forums VEGAS Pro Will Blackmagic Intensity / MX02 mimi work with Vegas? Which is best?
  • Will Blackmagic Intensity / MX02 mimi work with Vegas? Which is best?
    Posted by Ben Edwards on April 27, 2010 at 1:58 pm
    I am looking for a device that creates high quality conposit (RGB) out to connect to a broadcast CRT monitor. I am going to give a standard Matrox card a go but don’t hold much hope of this being much good.
    The Two devices I have found that may fit the bill is the Blackmagic Intensity (Pro or Shuttle) and the Matrox MX02 mini. The Blackmagic is £136 and the MX02 £300.
    So I have 4 questions
    1) Will I be able to set these up as preview device in Vegas Pro 9.
    2) Is the MX02 better than the Blackmagic, it is twice the cost.
    3) Should I go for the Blackmagic Intensity Pro or Shuttle. I guess the shuttle requires an additional USB3 card and breakout boxes are generally better but is there anything else I should know?
    4) Are there any other devices I should be looking at (That are under £300)?
    Regards,
    Ben
    Ben Edwards replied 16 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
