Activity Forums Adobe After Effects Will Adobe ever Fix that 3d object placement bug?
  • Will Adobe ever Fix that 3d object placement bug?
    Posted by April Henderson on August 19, 2009 at 6:18 pm
    Well you know on non 3d layers, bottom layers are the background and top are the front. However, even in 3d layers, sometimes the same thing occurs with 3d layers regardless of their 3d position assigned coordinates. A 3d position should be a fixed position. Instead I need to go sorting through dozens of layers to find out in what magical order I need to place it so one layer doesn’t appear in front of another.
    Miha Kokalj replied 15 years, 8 months ago 7 Members · 17 Replies
  • 17 Replies
  • David Bogie
    August 19, 2009 at 6:52 pm
    [April Henderson] “Well you know “
    I don’t know this as a bug at all; it just doesn’t seem to be an issue for most of us. My layers are always positioned in 3D space exactly where I place them. The user can easily get confused by the conflicts between world and object coordinate systems but the object’s ultimate 3D world placement is always exact in my compositions.
    bogiesan
  • April Henderson
    August 19, 2009 at 7:44 pm
    Really….? I notice this little error everytime I use AFX. I’ll make a screen capture video and post it on youtube.
  • Todd Kopriva
    August 19, 2009 at 8:43 pm
    If you consider something a bug, then let us know by filling out the feature-request/bug-report form.
    Here’s a page that describes what’s going on:
    “How render order and collapsed transformations affect 3D layers”
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • April Henderson
    August 19, 2009 at 9:03 pm
    Thanks. I might just be me too and or the confusion might lay in precomposed layers. When I notice again I will try and capture it.
  • April Henderson
    August 20, 2009 at 1:39 am
  • Adolfo Rozenfeld
    August 20, 2009 at 2:13 am
    It’s not a bug, April.
    If you follow the link to the AE Help page Todd posted above, you’ll find a list of operations which break the 3D compositing bin.
    Adolfo Rozenfeld · Adobe
  • Todd Kopriva
    August 20, 2009 at 2:45 am
    This isn’t an issue of “position”. It’s an issue of compositing order (or render order, to use other words).
    If the explanation in the page that I linked to in my previous answer doesn’t explain this adequately, let me know.
  • Brian Charles
    August 20, 2009 at 5:34 am
    April, there’s a 2D layer in the middle of your Comp. That’s what’s causing the layering issue. You need to keep all 3D layers together, placing a 2D layer between then creates 2 separate 3D world spaces hence the apparent “problem”.
  • April Henderson
    August 20, 2009 at 5:54 am
    Thanks for the advice. It seems on either side of the lux layer the anomaly occurs. I moved the 2d text layer in between my 3d layers and the sun just as a test, but it didn’t create any problem with my sun layer. Maybe it’s just the lux layer.
    I’ll read up on those other articles listed above. Collapsed transformations of precomposed layers have this issue too? It’s still rather a frustrating thing in my opinion. But I’ll investigate further.
  • Darby Edelen
    August 21, 2009 at 6:34 pm
    This isn’t really a bug. It’s just the way the AE renderer works.
    If you have any 2D layers (including adjustment layers and track mattes) in between 3D layers it will separate the rendering of the 3D layers and the depth sorting will be wrong.
    If, for instance, you moved your sun layer in your example to the top of the section with only 3D layers, it would still render properly sorted in depth. As soon as you move it above a 2D layer it’s going to basically render in a different 3D universe 🙂
    Darby Edelen
