Activity › Forums › Adobe After Effects › Will Adobe ever Fix that 3d object placement bug?
Miha Kokalj replied 15 years, 7 months ago 7 Members · 17 Replies
Darby Edelen
August 21, 2009 at 6:39 pm[April Henderson] “I moved the 2d text layer in between my 3d layers and the sun just as a test, but it didn’t create any problem with my sun layer.”
Was your sun layer still below the other 3D layers in the timeline? You’d need to place the layer above a 3D layer it’s supposed to be behind, then place a 2D layer in between them in order to break it.
Darby Edelen
April Henderson
August 22, 2009 at 5:55 amI was just playing around with some other 3d compositions. Nothing but simple colored layers! Exact same problems! Layers will appear in front of layers depending on order in the timeline. It’s a flawed 3d program.
Adolfo Rozenfeld
August 24, 2009 at 6:17 pmApril: If you follow the link posted by Todd, you’ll find an comprehensive list of procedures that will break 3D intersections.
Note that everyone in this thread said that this is the expected behavior, and it’s perfectly documented in the manual. It’s not a flaw or a bug. Do you know any 3D program with adjustment layers, for example? There are some tools which have 2D compositing logic in their very nature.Adolfo Rozenfeld · Adobe
April Henderson
August 24, 2009 at 7:02 pmI wasn’t referring to my previous composition. I just experimented with a new, large compositions of simply after effects 3d layers (ctrl-shift y) and I noticed the same phenomena, without any 2d layers whatsoever. It’s just the simple fact I’ve known for a long time, the render order dictates often what layers will be visible and not. And certain layer will pop out frequently from various angles.
When I originally asked, the only thing I was told was 3d layers will always appear in their assigned position. But that wasn’t exactly true.
Adolfo Rozenfeld
August 24, 2009 at 7:07 pmApril:
2D layers are not the only thing that can break the 3D compositing hierarchy.
Once more, please check the AE help page posted above for a full list.Adolfo Rozenfeld · Adobe
April Henderson
August 24, 2009 at 7:52 pmOk…I will study this more and come back with more intelligent questions/answers.
Miha Kokalj
January 11, 2011 at 12:18 pmIf this is not a bug why do i get a different result at different camera distances, with the same layer setup?
https://www.shrani.si/f/3O/h2/v0JkKlX/picture-32.png
https://www.shrani.si/f/z/Ne/oksNAsC/picture-22.png
