Activity › Forums › Adobe After Effects › Will actual 64Bit Plugins still work in CS5
  • Will actual 64Bit Plugins still work in CS5
    Posted by __peter__ on January 30, 2010 at 6:23 pm
    Hello 🙂
    I’ve read that CS5 will only support 64Bit plugins.
    I am interrested in Colorista and found that it already supports 64Bit systems.
    So does that mean it will run in CS5 which will only be 64Bit ?
    If not, I would wait, as CS5 seems to be just around the corner.
    If yes I could buy it now with the good feeing for my actual CS3 32Bit version.
    Peter
    __peter__ replied 16 years, 8 months ago 3 Members · 6 Replies
  • Todd Kopriva
    January 30, 2010 at 7:04 pm
    There’s a difference between “supporting 64-bit operating systems” and the plug-in (library) itself being a 64-bit library. Any 32-bit application (and its libraries) can run on a 64-bit operating system. The real question is whether the plug-in itself is 64-bit to enable it to run when loaded into a 64-bit application.
    Disclaimer: I don’t know the details of Colorista. You should really ask these sorts of questions directly to the makers and distributors of the software—in this case Red Giant.
    I encourage people to have conversations about 64-bit After Effects and 64-bit plug-ins in general with Michael Coleman, the After Effects product manager. There’s already a conversation going in the comments on his blog. Having the conversation on a bunch of disparate forums seems to be a recipe for half-information and confusion.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • __Peter__ Create COW Profile Image
    __peter__
    January 30, 2010 at 7:10 pm
    So I will ask Red Giant Software.
    What I didn’t completely understand from Your answer is, if it will work or not 🙂
    You mean it works in any case but maybe cannot use the advantages of a 64Bit Plugin. Which means I still cannot use as much memory. Right ?
    Peter
  • Todd Kopriva
    January 30, 2010 at 7:15 pm
    To work with a 64-bit application, the plug-in must be a 64-bit plug-in. I don’t know whether Colorista is already available as a 64-bit plug-in. Ask Red Giant that. What I do know is that a statement that a plug-in “supports 64-bit operating systems” is not the same as the crucial statement that the plug-in itself is a 64-bit plug-in.
    __peter__
    January 30, 2010 at 7:25 pm
    OK, thanks.
    Peter
  • Matt Silverman
    January 30, 2010 at 10:19 pm
    Short answer is “no”. The current version of the plug-in you buy today will not work in CS5. You need a 64bit plug-in.
    Since AE CS5 is not out yet, no 3rd party devs have released 64bit plug-ins. I am assuming most vendors will be charging for 64bit upgrades. Porting is not a simple process and requires development time (depending on the plug-in could be significant re-writing) and they probably will want to be compensated for this. Your best bet is to contact the plug-in vendor and see if they can cut you a deal for a free upgrade if you order now. Some might bite…
    __peter__
    January 30, 2010 at 10:59 pm
    Thanks for the short answer 🙂
    I wrote to RedGiantSoftware and wait what they have to say.
    But in general that’s a interesting question for all plugins.
    Who would buy anything now if there is no clear statement what will be when we have no other choice than the 64Bit version.
    Peter
