Activity Forums Adobe After Effects Wiggler expression help please
  • Wiggler expression help please
    Posted by Mark Chivers on June 27, 2006 at 2:11 pm
    Hi
    I have this expression on a layer :
    wiggle(30,30)
    Its a simple shake – but i want to be able to ease into the shake slowly then, eventually ease out – i tried applying keyframes but it didnt seem to work – Anyone got any idea how to do this?
    Many thanks
    Motion169
    Mike Clasby replied 20 years, 3 months ago 2 Members · 3 Replies
  • Mike Clasby
    June 27, 2006 at 4:11 pm
    Short Answer, Slider and pickwhip.
    Since your Frequency and Amplitude are equal (30,30), put a slider on your layer (Effect>Expression Control>Slider Control), then put on this expression:
    wiggle(effect(“Slider Control”)(“Slider”),effect(“Slider Control”)(“Slider”))
    You could have gotten there from your expression:
    wiggle(30,30)
    by hitting “e” to expose the slider, hitting “ee” to expose your original expression, wiggle (30,30), highlighting(select) one of the 30’s, then pickwhip to the slider, then doing the same for the other 30).
    Setting a keyframe on the slider for 0, then 30 down the line will make the layer go from 0 to 30 wiggle-wise (not exactly ease, I’m still fiddling with that.)
  • Mark Chivers
    June 27, 2006 at 4:18 pm
    Thanks mate – looks like a winner!!
    Cheers for all you help!
    Motion169
    __________________________
    https://www.motion169.co.uk
  • Mike Clasby
    June 27, 2006 at 4:21 pm
    Hello… (to myself), Well just select your slider keyframe and hit F9 to make then Ease keyframes, methinks.
