Activity › Forums › Adobe After Effects › Wiggler Blurs Footage?
Posted by Jared Peace on March 26, 2010 at 1:50 amHola Creative COW.
Looks to me like the Wiggler in After Effects also adds a slight blur to a shot, at least when working with interlaced footage. Is this correct? Is this avoidable?
Thank ye.
Scott Novasic replied 16 years, 6 months ago 2 Members · 3 Replies -
Scott Novasic
March 26, 2010 at 3:53 amfirst I would separate the fields. Interlaced footage can be tricky. Is there a natural motion blur to the footage to begin with? and stating the obvious, check that the Motion Blur setting is off.
SuperNova
Animation & Visual Effects
Scott Novasic
Los Angeles Ca
web:https://web.mac.com/finaleffects -
Jared Peace
March 26, 2010 at 4:10 amThanks for the response.
Motion blur is off. Fields are properly interpreted and I’ve also tried running the Wiggler effect on a 59.94fps comp with fields fully separated. No change. The shot itself is static so the blur is definitely being added by Wiggler. Also the footage is uncompressed 8-bit, so this isn’t a problem of recompression.
It really just appears to me that the Wiggler effect adds a slight amount of blur as part of its functioning. It’s fairly subtle so it could be that most people just accept it/don’t notice it, but it is there.
Thinking about how fields are processed, I actually can’t imagine how horizontal position could be adjusted by any program or effect WITHOUT creating blur. Magic, maybe. I was kind of hoping someone on the COW could send some magic my way.
Jared
https://www.jaredpeace.com -
Scott Novasic
March 26, 2010 at 4:00 pmwell, Jared. You know your stuff. That tells me, without seeing a frame of it that you are right, that simply distorting an image over a number of pixels. Say taking a 3 pixel wide sharp line and distorting it
to 3 or 4 times inevitably will lead to same ‘softening\blurring’ of an image. My thought is that if you want it as ‘focused’ as as possible try a ‘median’ filter or any number of more robust sharpen filters to help the image a bit.Good luck.
SuperNova
Scott Novasic
Los Angeles Ca
