Activity › Forums › Adobe After Effects Expressions › Wiggle Transform Shape Layer – Loop wiggle?
Posted by Jason Jantzen on February 21, 2015 at 8:17 pmI saw Dan’s loop expression for wiggle, but is there a way to loop the wiggle transform animator on a shape layer? Any ideas?
Jason Jantzen
vimeo.com/jasonjFilip Vandueren replied 7 years, 3 months ago 4 Members · 5 Replies -
Jason Jantzen
February 21, 2015 at 8:29 pmWell, in the infinite void of creative block I’ve experienced this morning, somehow I managed to make this work. I just popped his looping wiggle expression into the temporal and spatial phase parameters and “oula!” It worked.
Jason Jantzen
vimeo.com/jasonj -
Peter Chicarielli
September 24, 2018 at 1:27 amHey!
I’m searching around to find the difference between spatial and temporal phase under the wiggle settings. I haven’t come across much information to be honest. Most videos are concentrating on the scale, rotation, position etc. settings.
I am using a wiggle loop custom expression for a tutorial, and they are actually suggesting to use it within the spatial or temporal settings, or both like you did, but I’m still unclear what these settings actually do.
It’s been three years since you posted this, but if you can shed any light on this topic, I’d appreciate it!
Pete -
Alena Titova
May 13, 2019 at 8:43 pmPlease share your expression! I’m trying to solve exactly the same problem. Thanks
Filip Vandueren
May 14, 2019 at 8:16 pmThink of wiggle() as a 2D field of random undulating (Perlin) noise that’s changing at the rate of Wiggles/second.
Now if you have two identical shape layers with a Wiggle Paths that have the same seed value which is not equal to 0 ! (0 is a special value that is always random).
Then those two layers will look and wiggle identical.Now if you use Temporal Phase difference, one layer will still be deformed the same as the other, but a bit earlier or later in time, Just a basic time delay in the changing noisefield.
Spatial Phase would tell the wiggle to get it’s random values somewhere else on the 2D field, if it’s spatially close, the noise will be pretty similar (correlated) to the original value.
Filip Vandueren
May 14, 2019 at 8:37 pmMy method of making Wiggle Paths be loopable is this:
– set wiggles per second to 0;
– expression for Temporal Phase:
wigglesPerSecond = 1.5;
loopTime = 3.5;
Math.cos(degreesToRadians(360*time/loopTime))*360*wigglesPerSecond + value;
– expression for Spatial Phase:
loopTime = 3.5;
Math.sin(degreesToRadians(360*time/loopTime))*360*wigglesPerSecond + value;
