Activity Forums Adobe After Effects Expressions Wiggle expression to mimick a faulty street light?
  • Wiggle expression to mimick a faulty street light?
    Posted by Jon Melot on October 3, 2013 at 6:58 pm
    Hello all,
    I’ve got a scene set up with where I’ve got an street light that I want to make flicker and light light up the whole scene. I’ve put an expression on the are with the light that is affecting the opacity of the “light”. Then I have a black solid that has been masked to light the scene like I want that is linked to the previous light layer.
    So the wiggle expression I am using on the “light” layer to drive opacity is: wiggle(5,75)
    The expression I’m using on the black solid to simulate the lights going out over the whole scene is: 125-thisComp.layer(“Lightintense light flickr”).transform.opacity
    sorry for crappy naming convention 😉
    The problem is that the flickering ends up looking kind of like candle light. Also, it is non stop. I’d like the light to be okay for a second or two, then have some heavy flickering, then back to full… then to have that type of cycle keep repeating. Basically I just want to make a flickering lamp that doesn’t look like a flickering candle, and that doesn’t necessarily flicker every second of the composition. any ideas? I’m sure there’s some simple idea I’m missing. Any help would be most appreciated.
    Thank!
    Pierre-alexis Tremblay replied 12 years, 11 months ago 2 Members · 1 Reply
  • Pierre-alexis Tremblay
    October 3, 2013 at 9:27 pm
    To get control over the wiggling I like to link each wiggle parameter to a keyframed expression slider control (one for amplitude and one for frequency).
    P.A.T.
