Activity Forums Adobe After Effects wiggle expression on 3D layer making image disappear behind other 3D layer
  • wiggle expression on 3D layer making image disappear behind other 3D layer
    Posted by Scott Green on September 16, 2009 at 1:46 pm
    I’m having trouble getting a 3D layer just to wiggle just on X and Y, because when it wiggles in Z space the layer disappears behind the 3D layer positioned behind it.
    Can you tell me what expression I need to use to stop the position wiggling in Z space please? Thanks.
    https://www.splurj.com
    Paul Conigliaro replied 16 years, 11 months ago 2 Members · 3 Replies
  • Paul Conigliaro
    September 16, 2009 at 2:27 pm
    pos = wiggle(.5,20);
    [pos[0], pos[1], transform.position[2]]
    This will lock the z position to whatever is manually set. Change the wiggle to whatever you need.
    Adobe CS3, Apple FCS2
    [Disclaimer: Sometimes I am an idiot and misinterpret people’s posts. I’m sorry.]
  • Scott Green
    September 16, 2009 at 3:17 pm
    That’s great thanks, I’m just trying to understand the script and figured that the positions are in order of [X, Y, Z] so if I didn’t want to affect the X position for example I’d put:
    [transform.position[2], pos[0], pos[1]]
    but can you tell me what the [0], [1] and [2] are for please?
  • Paul Conigliaro
    September 16, 2009 at 3:21 pm
    0,1, and 2 correspond directly to x,y,z in both wiggle and the transform.position. So if you want to keep just the x position, it would be:
    [transform.position[0], pos[1], pos[2]]
