Activity › Forums › Adobe After Effects Expressions › Wiggle Expression
  • Steve Roberts
    May 11, 2005 at 7:22 pm
    Set up the amplitude (amp) as a variable, and link it to an animated “expression controls” slider effect in the same layer.
    Apply the expression controls effect, using a slider. Make it visible in the timeline. Apply the wiggle expression with a value for freq, but leave amp as is, and write amp= ; in a line above the expression. With the cursor in the space after the = , pickwhip to the slider.
    Now the amp value is determined by the slider value. Animate the slider value, and the amplitude of the wiggle will follow.
    Steve
  • Mike Clasby
    May 12, 2005 at 12:28 am
    Wow, that is great.
    And implementing the slider was a snap. Now I can see how it can be done easily.
    Thanks.
