Activity Forums Adobe After Effects Expressions wiggle but still being able to control overall positon
  • wiggle but still being able to control overall positon
    Posted by Craig Hellen on July 17, 2013 at 12:13 pm
    Hey Guys,
    Got a (probably) really simple thing to sort out,
    I have a comp with a bunch of layers distributed in 3d, camera pulling back through it, layers having position keyframes to alter their location in relation to the camera (see images attached)
    We are wanting to create a “slight float” for all the notes on screen but when I apply a basic wiggle tio create the float it obviously disregards the keyframes for the movement that is currently there…
    What’s the simplest way to sort this out?
    Yours in after effecting
    Craig
    Co-Director Podchains Ltd
    Video Producer / Motion graphics designer https://bexmedia.net
    Mitch Mann replied 13 years, 1 month ago 4 Members · 3 Replies
  • Jeff Kay
    July 17, 2013 at 3:25 pm
    EDIT: Durr, I had forgotten that wiggle() doesn’t overwrite keyframes. See Dan’s post below.
  • Dan Ebberts
    July 17, 2013 at 4:17 pm
    wiggle() is unusual in that it doesn’t replace the keyframed value–the wiggle automatically includes the keyframed value. I’m not sure what your issue is unless you have the amplitude so high that it’s overwhelming the original motion.
    Dan
  • Mitch Mann
    July 17, 2013 at 4:18 pm
    Just keyframe it along your path, then add this expression to the position:
    wiggle(10,100)
    And is should wiggle along the path of the keyframes.
