Activity Forums Adobe After Effects Expressions Wiggle and layer order
  • Wiggle and layer order
    Posted by Alex Dinnin on February 16, 2009 at 6:14 pm
    Could someone help me out please ???
    I have applied the following expression to the position on about 12 layers.
    x=wiggle (.8,250) [0];
    y=wiggle (.6. 205) [1];
    {x,y]
    It works a treat, randomly moving the layers about..
    HOWEVER… whenever I change the layer order.. the animation completley changes..
    is this expression controlled by layer order ??
    It’s not the end of the world.. just a little bit irritating..
    anyone know of a fix ???
    regards
    Alex
    Alex Dinnin replied 17 years, 6 months ago 2 Members · 4 Replies
  • Dan Ebberts
    February 16, 2009 at 9:59 pm
    If you like a particular wiggle, you can just add a seedRandom() call with the current layer number minus 1. For example, if you like the layer’s wiggle as layer 1, use this:
    seedRandom(0);
    y=wiggle (.6, 205) [1];
    [x,y]
    Dan
  • Alex Dinnin
    February 17, 2009 at 9:50 am
    Hi Dan,
    OK.. I added your expression and AE didn’t like it at all, I put in the layer number randomseed (7);
    but it didn’t like it, then tried pickwhipping the whole layer, but still no.
    I tried a it with just random, which the expression was happy.. it’s just didn’t do anything.. when I moved the layer, they still changed position.
    any ideas ??
    thanks for your continued help
    Alex
  • Dan Ebberts
    February 17, 2009 at 2:29 pm
    So if you copy and paste the expression from my post into a postion expression it generates an error? What’s the error message.
    By the way, I don’t know if this is the problem or not, but it’s seedRandom(), not seedrandom().
    Dan
  • Alex Dinnin
    February 18, 2009 at 3:53 pm
    Hi Dan,
    Sorry it must have been finger trouble.. tried it again today and it works fine..
    I still don’t really understand how it works..
    but thanks anyway
    regards
    Alex
