Activity Forums Apple Final Cut Pro Legacy Wierd strobiness (starts ramndomely) on Multiclip playback mostly
  • Wierd strobiness (starts ramndomely) on Multiclip playback mostly
    Posted by Ariel Brener on October 26, 2010 at 11:16 am
    Greeting..
    Something very weird happens:
    I Edit HD multi-cam footage.
    Every thing works great and smoothly.
    but after a while – and I cant point specifically when or after what action.
    when I hit “play” I get a strobe picture.
    also when I turn off the multi clip playback
    and even if I play back regular non-multiclip footage. with no effects (render bars are grey).
    when I relunch FCP problem continues.
    only after restart it comes back to normal playback.
    I have two intel mac pro on the network.
    maybe it has something to do with that?
    maybe cluster render settings are set wrong?
    I get the same problem on the other machine as well (but less often)
    Did any of you good people expeariance it?
    Any ideas?
    thanks!
    Ariel Brener replied 15 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
