Activity Forums Apple Final Cut Pro Legacy Wierd frame rate with Batch capture
  • Wierd frame rate with Batch capture
    Posted by Sean Davison on November 14, 2006 at 9:48 pm
    Im using a BM HD Pro card with FCP 5.2
    If I digitise a clip using capture now the quicktime file shows it has a frame rate of 25 fps
    If I use Batch capture the quicktime file reports a widly varying frame rate.
    This is OK while in FCP which seems to deal with this and play all clips at the right frame rate
    But if I try importing the clips into another programme ie Final touch It renders the file with dropped frames (not surprisingly)
    Anybody know why this is?
    Sean Davison replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
