Activity Forums Adobe After Effects widescreen to anamorphic question
  • widescreen to anamorphic question
    Posted by Frank Ruggiero on May 10, 2006 at 3:03 pm
    Hi Cow Members,
    Can anyone tell me the best way to do this. I have received a quicktime file that is 864 x 486 SQUARE pixels. It is intended for a widecreen display. I simply want to convert it to anamorphic for output to Digital Beta.
    Can I just export a new file in Quicktime and set the size of the output to 720 x 486? (Do I need worry about square / non square issues?)
    Or should I take it into After Effects and nest it into a 720 x 486 comp? If I do it that way, should the 720 x 486 composition be Square pixels or non-square?
    Thanks in adavnce.
    -Frank R.
    Frank Ruggiero replied 20 years, 4 months ago 8,467 Members · 2 Replies
  • Frank Ruggiero
    May 10, 2006 at 3:11 pm
    i think i figured out the answer. can anyone confirm this?
    i bring the 864 x 486 file into After Effects and put it in a D1 / DV NTSC Widescreen 720 x 486 Comp . Then I render it out from there.
    thanks, Frank
  • Frank Ruggiero
    May 10, 2006 at 5:08 pm
    right,
    if the video has fields, i would interpret it and render it with fields. thanks for the confirmation.
    frank
