Activity Forums Adobe Premiere Pro Widescreen Problem CS3
  • Widescreen Problem CS3
    Posted by Lalo Landa on July 13, 2008 at 7:44 pm
    Hello,
    I’m having problem exporting widescreen proyects. I live in Argentina, so we use PAL video. When I export my proyect, the “widescreen” lines aren’t there, they are on the left and right side of the screen, kinda distorting my image…
    What should I do? 🙁
    Lalo Landa replied 18 years, 1 month ago 4 Members · 5 Replies
  • Glenn Triggs
    July 14, 2008 at 6:04 am
    try exporting your video through ‘adobe media encoder’ i like australia and we use pal too. select mpeg 2 – and whatever settings you need after that – depending on qual and interlaced –
    that should hopefully do the trick. what are you using to watch the footage back on??? i like vlc media player – it’s free and plays everything and anything
  • Lalo Landa
    July 14, 2008 at 7:53 am
    Thanks, it worked perfectly.
    I use Classic Media Player.
  • Tim Kolb
    July 14, 2008 at 12:46 pm
    Windows Media Player does not interpret pixel aspect ratios other than square quite often…
    TimK,
    Director, Consultant
    Kolb Productions,
    CPO, Digieffects
  • Perry Cheng
    July 15, 2008 at 12:12 pm
    Perhaps he meant “Media Player Classic”, which is not the same as regular Windows Media player (Open source?). BTW, I use KMPlayer, free as well, like VLC.
    Perry
  • Lalo Landa
    July 15, 2008 at 2:41 pm
    Oh, you’re right. I meant that one. “Media Player Classic”.
    Thanks for pointing that out.
