Activity › Forums › Adobe After Effects › widescreen pixel apsect question
  • widescreen pixel apsect question
    Posted by Frank Ruggiero on September 7, 2005 at 5:48 pm
    Dear Cow forum,
    I want to supply widescreen graphics. I understand that I should build them at 864 x 486 and then squeeze it to 720 x 486 to output an anomorphic movie to digital beta. Should I not be working in non-square since the monitor it is going to will probably be a non square monitor? I see some people are working in a square composition.
    Any info would be great.
    Frank R.
    Steve Roberts replied 21 years ago 2 Members · 1 Reply
  • Steve Roberts
    September 7, 2005 at 6:46 pm
    A square-pixel comp has dimensions that match the desired ratio:
    864×486 is 16:9.
    648×486 is 4:3.
    720×540 is 4:3.
    People work in these square pixel comps because objects appear correct in them when working on a computer. It is entirely correct to then drag these comps into a non-square comp and using ctrl-alt-F to fit to the comp. The non-square comp is then rendered to produce a non-square-pixel 720×486 movie that will look correct on TV sets.
    You can also work in a non-square comp and select pixel-aspect-ratio correction to temporarily correct things for the computer. You then switch it off before you render.
    Either way is correct.
    Steve
