Activity Forums Adobe Premiere Pro Widescreen or a setting not set correctly?
  • Widescreen or a setting not set correctly?
    Posted by Costas Damianou on October 9, 2006 at 8:12 pm
    Hi
    I am trying to understand something which is bugging me.
    I have a Panasonic GS270. I have extracted the footage and it shows perfectly, but when i click to watch the clips, in the right hand monitor it doesn
    Joe Castiglioni replied 19 years, 11 months ago 3 Members · 4 Replies
  • Dickij
    October 9, 2006 at 8:16 pm
    I’m not sure if I understand your problem correctly – but have you tried right-click on the item in the project window and click ‘Interpret footage’. If you have a widescreen clip, click ‘conform to’ and select the correct widescreen option (1.422 for PAL etc).
    Hope that helps.
    Jamie
  • Costas Damianou
    October 9, 2006 at 8:43 pm
    I hope this helps to understand my problem.
    The footage shows like this https://www.magicchat.co.uk/clipa.gif
    Hower it ends up like this https://www.magicchat.co.uk/clipb.gif when its in the timeline.
  • Costas Damianou
    October 11, 2006 at 9:17 pm
    Anyone have any idea of this problem?
    Thanks in advance
  • Joe Castiglioni
    October 12, 2006 at 2:17 pm
    Sounds like you just need to resize the footage. For example, shooting with DVCPro 25 in widescreen format, we have to resize the image to 75% in order to get it to look like that first picture. The rest of the video is still there, just hanging off the edges. That’s what works for us. You can copy and paste the “Motion” properties from one clip to others to save time when scaling everything to 75%. Let me know if this helps, or if it’s a totally different problem.
