Activity Forums VEGAS Pro widescreen format
  • widescreen format
    Posted by Tom Delacarey on April 26, 2008 at 2:11 pm
    I had been having some issues with integrating still’s with video to make thm the same rendered format. Now that they are, the widescreen finished rendered product is really weird. The image is really squashed and the black there is a black border on the sides of the video a well as the top and bottom both of which are extremely thick. Please help.
    Mike Kujbida replied 18 years, 4 months ago 6 Members · 12 Replies
  • 12 Replies
  • Mike Kujbida
    April 26, 2008 at 2:32 pm
    Tom, make sure your Project Properties (File – Properties) are set to widescreen, then open Pan/Crop on a still.
    Right-click and select “Match Output Aspect”.
    See if that fixes it for you.
  • Charles Avanti
    April 26, 2008 at 6:52 pm
    Also, if your looking at a DVD you made, be sure the properties in DVDA and also set to widescreen. I assume your viewing this on a widescreen 16:9 TV.
    Charlie
  • Tom Delacarey
    April 26, 2008 at 6:59 pm
    it really helped the video widescreen format, but the stills are still squashed. I don’t get it. I fixed the stills in the pan crop. is there some way to do this manually?
  • Tom Delacarey
    April 26, 2008 at 7:05 pm
    the still image is labled as a jpeg compression. Does that mean anything?
  • Charles Avanti
    April 26, 2008 at 7:06 pm
    Try: In the pan/crop of a still, choose “match aspect ratio of project”.
    Charlie
  • Tom Delacarey
    April 26, 2008 at 7:14 pm
    how do I do that?
  • Tom Delacarey
    April 26, 2008 at 7:33 pm
    really sorry, I found the problem; I had saved the stills wrong
  • Mike Kujbida
    April 26, 2008 at 10:12 pm
    How would saving the stills wrong affect things?
    Or was it a case of saving in portrait mode instead of landscape?
  • Rick Mac
    April 27, 2008 at 3:48 pm
    Tom,
    Here is a link to a tutorial on how to use the pan/crop tool.
    The first part tells you how to fill the screen with your still. Then it goes into how to zoom in and out of your stills using the pan/crop tool. You will have to register at the site before you can view but it is free. Bookmark this site as it has a ton of free tutorials covering Vegas. They also sell some of the best videos and books for Vegas that you will find anywhere.
    https://www.sundancemediagroup.com/tutorials/pan-crop.htm
    Regards, Rick.
    Rick Mac
    Director of Audio Production
    TCT Network – Directv 377
  • Edward Troxel
    April 27, 2008 at 6:55 pm
    Vol 1 #8 of my newsletters also shows how to use Pan/Crop on photos to create a slide show.
    Edward Troxel
    JETDV Scripts
