Activity Forums Apple Final Cut Pro Legacy Widescreen and Motion Problem
  • Widescreen and Motion Problem
    Posted by Nathan Mckay on September 9, 2011 at 3:44 pm
    I’m using the Widescreen 2:35 filter in FCP. It works great, but there’s only one problem: when I “digitally zoom in” on a clip under the motion tab by increasing the scale, Final Cut also zooms in on the Widescreen layer, making it thinner. As I cannot custom size the Widescreen, I am stuck. I really need to be able to zoom in on some shots and I have no idea how to fix this. Perhaps there’s a different way to put Widescreen on my clips? Help!
    Neil Ryan replied 15 years ago 4 Members · 5 Replies
  • Nathan Mckay
    September 9, 2011 at 3:54 pm
    Unfortunately I do not have own Photoshop. Can someone here make one and upload it? Or send it to me via email nmckay3@gmail.com
  • Nathan Mckay
    September 9, 2011 at 4:04 pm
    Nevermind! Found a widescreen generator online that solves the problem. Thanks for the help!
  • Kent Beeson
    September 9, 2011 at 4:41 pm
    Bit of a work-around but put your zooming-in clip in its own nested clip and add the 2:35:1 filter to that…might work
    K
  • Andrew Kimery
    September 9, 2011 at 5:27 pm
    I just place two slugs on the top video tracks and use them to mask out the top and bottom of the image.
    -Andrew
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
  • Neil Ryan
    September 12, 2011 at 4:38 am
    Whilst you got around it this time, it would pay for you to understand the original problem, as you’re bound to come across it again.
    The issue you had stems from the order in which FCP process. Effects come after Motion Tab.
    From the online help: (When it says ‘rendered’ read ‘processed’ for a better understanding)
    Order of Effects Rendering
    When you render effects in a sequence, they’re rendered in the following order:
    The top video track (the highest-numbered track) is rendered first and then composited onto the track below.
    Within each track, effects are rendered as follows: speed, filters, motion, motion blur, opacity, and transitions.
    You can change the order of rendering by using nested sequences. For more information, see Sequence-to-Sequence Editing.
    This is why you should take note of Kent’s workaround.
    Neil.
