Activity Forums Adobe Premiere Pro widescreen 16:9 and standard 4:3 in premiere pro 7
  • widescreen 16:9 and standard 4:3 in premiere pro 7
    Posted by Olaf Steel on May 5, 2008 at 11:00 am
    hi,
    i started a project with standard 4:3 settings, however, i have some footage that was shot 16:9. Premiere seems to automatically compress the 16:9 footage to 4:3, but how can i make the entire project 16:9? keep in mind i have already started my project on standard 4:3.
    thank you,
    olaf
    Paul Scott replied 18 years, 4 months ago 3 Members · 4 Replies
  • Harm Millaard
    May 5, 2008 at 11:12 am
    You can’t. You need to start a new project.
    Harm Millaard
  • Olaf Steel
    May 5, 2008 at 11:14 am
    is there any way i can bring everything from my old 4:3 project into a new project without loosing anything?
    olaf
  • Harm Millaard
    May 5, 2008 at 11:30 am
    Import the existing project into the new one.
    Harm Millaard
  • Paul Scott
    May 6, 2008 at 5:29 am
    First make a quality Mpeg of your 4:3 project.
    Then what I do,
    is start a NEW 16:9 project,
    and then import the 4:3 project.
    Import into a different bin to your new project so as not to mess up sequences and so on.
    From now on stick with the 16:9 project.
    Be careful about your labeling so you know what is what.
    Now, Get the 4:3 project into the timeline and arrange it best by pixel formations { down here we convert pixels to 1.33 for 720 by 576 ]
    or alternatively within “Effects control” or standard effect “Motion” [ switch of scale control ] and change the scale so the 4:3 Mpeg fits in the way you want.
    Sometimes I make photoshop frames in yellow colours to check the dimensions .
    Then render and check it out.
    It should work, I have to do it all the time.
    paulscottfilms
