Activity Forums Adobe After Effects Why would my X rotation be rotating on the z axis?
  • Why would my X rotation be rotating on the z axis?
    Posted by Brad Ballew on October 17, 2010 at 2:25 pm
    So I just imported a camera from boujou into after effects cs5. I made me video a 3d layer and was adjusting it behind my tracking points to match the cameras frame. The first time I started changing the values in the X rotation it worked as it should. Suddenly now when I go to change the values under X rotation is rotates my video on the z axis. I cannot understand why this would possibly be happening. The z axis values rotate on the z axis and my x values also rotate on the z axis. It’s very frustrating. It has happened twice in a row now, so it wasn’t a one time glitch. Has anyone ever run into this problem?
    Tudor “ted” jelescu replied 15 years, 10 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    October 17, 2010 at 5:37 pm
    Do not adjust the rotation controls of the layer- link the layer to a series of Nulls (one for each adjustment you have to make) and adjust rotation this way.
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
