Activity Forums Adobe Premiere Pro Why wont any new fonts I install in Windows appear under Title in Premiere?
  • Why wont any new fonts I install in Windows appear under Title in Premiere?
    Posted by Dave Andrade on July 10, 2015 at 6:44 am
    Windows 7 machine. PP 2015, but was happening in 2014. The list of fonts available for Titles is MUCH smaller than with any other options for fonts. Why? And how do I expand that list?
    No other screen/application has an issue. Is “Title” limited to only those fonts? I find that strange.
    Ht Davis replied 11 years, 1 month ago 3 Members · 2 Replies
  • Tim Kolb
    July 10, 2015 at 8:29 pm
    What sort of fonts are you installing? It should see standard-compliant fonts…some of the free/shareware stuff can be a little sketchy…
    TimK,
    Director, Consultant
    Video Producer at I-CAR
  • Ht Davis
    July 15, 2015 at 2:20 am
    True-type fonts usually are more compatible. Open type fonts can have issues on occasion, based on the encoding program used. Conversion usually fixes any issues and conforms a font to the standard space.
    Also, you need to make certain you installed the fonts correctly, so you may want to check your registry for the fonts. Google it. If you can’t find the fonts there, you need to try reinstalling them.
