Activity Forums Apple Final Cut Pro Legacy Why wont all offline media Relink in one go?
  • Why wont all offline media Relink in one go?
    Posted by N1 Gooner on May 11, 2005 at 4:11 pm
    All the media was captured to an internal drive and then copied to an external firewire drive. When I attempted to relink the clips to the Firewire media it only linked about 75% of the clips in one go even though I checked ‘link all in path’ or whatever its called. Why didn’t it relink the rest? I then had to manually highlight the remaining offline clips and relink them one by one. If I tried to relink, say 5 clips at a time, it would only show one highlighted clip so I stopped in case it relinked all 5 clips to the higlighted media files. Was I mistaken? How can I ensure all clips get relinked in one go?
    Kevin Monahan replied 21 years, 4 months ago 3 Members · 3 Replies
  • Jeff Handy
    May 11, 2005 at 5:10 pm
    Keep going from there. You almost had it! There is also a little check box to ensure files with the same relative location will relink. As long as all of the files highlighted are in the same location, it will work.
    HandyGeek
  • Jeff Handy
    May 11, 2005 at 5:11 pm
    I’ll add the one caveat that you may have to manually relink each of the ones that didn’t work. I have had cases where all of the media was in the same location, but only some of them relinked. Just have to try it.
  • Kevin Monahan
    May 11, 2005 at 5:25 pm
    Use the Media Manager to move your stuff and it will be relinked automatically.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
