Activity › Forums › Apple Final Cut Pro Legacy › Why the Squish? DVD-destined Apple Pro Res Exported at Current Settings in QT
  • Why the Squish? DVD-destined Apple Pro Res Exported at Current Settings in QT
    Posted by Ann Silenza on March 4, 2010 at 7:48 am
    Hey smarties,
    I have 5 different 60 min programs of material to turn to DVDs, made up almost entirely of text created in FCP.
    I need to find the best way to put this content on DVDs. The priorities are 1) effenciancy (need this by Friday night) 2) quality (it will be on a big screen and watched by a lot of people).
    The sequence settings are – and this is where I feel clueless – some blend of Uncompressed NTSC 8bit and Apple ProRes. When I opened the sequence originally, I said make it Uncompressed 8… and then in the Sequence Settings I set the “compressor” to be Apple ProRes per the advice of Creative Cows.
    Here are my seq settings:
    Here is how it looks in my FCP viewer at 100%:
    Here’s how it looks after export in QT Current Settings:
    Q: Why the squish? Does this have something to do with square pixels?
    Q: What’s my ideal workflow with these settings, going from (what I think is) Apple ProRes 422 –> DVD? Do I want to export at Current Settings then go to Compressor to do DVD Settings then go to DVD Studio pro? Is it advisable to skip any of these steps. I also have After Effects if that’s advisable.
    Q: Since the files are big and I am on a tight deadline, is it advisable to make reference files instead of self-compressed?
    Thank you all,
    Ann
    Ann Silenza replied 16 years, 7 months ago 1 Member · 1 Reply
  • Ann Silenza
    March 5, 2010 at 4:41 am
    Solved – the squish went away after I put the files through Compressor.
