Activity › Forums › Adobe After Effects › Why the object change its location even if I didn’t change the keyframe?
  • Why the object change its location even if I didn’t change the keyframe?
    Posted by David Hall on August 18, 2015 at 6:20 am
    While the key frame remains the same, but the main logo changes it location to the left top corner when the timeline shift to a certain place.
    By the way, could you guys tell me how to post a image directly in the post?
    I can see the image in the preview mode when I’m using the code to show it but it appears the codes after I post.
    David Hall replied 11 years, 1 month ago 2 Members · 3 Replies
  • John Cuevas
    August 18, 2015 at 1:03 pm
    To post an image directly in your post, use the third to last icon above the reply box. Upload the image. When it’s uploaded select the image, then copy the “embed” code and paste it into your post.
    As to why your logo is jumping, you need to twirl open the logo(press UU), so we can see what effects, transformations, ect. you’ve applied to it. I can see an FX is enabled, but without knowing what it is, it’s hard to diagnose what could be happening.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • David Hall
    August 19, 2015 at 5:31 am
    Hi there,
    I uploaded two problem files.
    The llama one, the one I mentioned in my index post, has no problems now once I restart my after effects.
    But I still have the “location change” problem when I’m using adobe media encoder to encode the aep file into a mp4 version.
    The problem is I can only encode perfectly in Youtube 720HD, none of other resolutions work.(still the same problem, the logo “818” change its location after I encode it)
    BTW, let me try to post a image here.
  • David Hall
    August 19, 2015 at 5:32 am
