Activity › Forums › Adobe After Effects › Why the footage in edit mode is sharper then the uncompressed exported
  • Why the footage in edit mode is sharper then the uncompressed exported
    Posted by Mandeep Singh on July 21, 2010 at 8:02 pm
    I am exporting a 1080i footage from adobe after effects and the difference between the rendered can be obiviously seen when placed in the same composition. the rendered file has blurriness , or in other words its not as sharp as it was or is showing up in after effects project. Which settings will not change the quality of what i see in edit
    Richard Harrington replied 16 years, 2 months ago 4 Members · 4 Replies
  • Michael Szalapski
    July 21, 2010 at 8:41 pm
    You’ll want to make sure your interlacing settings are correct (both on the interpret footage and in the render queue. What “correct” is, varies depending on source footage and final output.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Andy George
    July 21, 2010 at 8:44 pm
    Do you have 3d layers with motion blur enabled? By default AE does not preview motion blur you have to turn it on. It’s in the upper right hand corner of your composition window. The button looks like 4 lines with an arrow next to it.
    Are you enabling Frame rendering frame the render Q? The default is progressive.
    -Andy George
    Senior Editor
    http://www.chiselindustries.com
  • Andy George
    July 21, 2010 at 11:48 pm
    I meant to say : Are you enabling frame rendering “in” the render Q?
    -Andy George
    Senior Editor
  • Richard Harrington
    July 22, 2010 at 5:39 am
    It all depends which codec you are rendering to. Your post lacks a lot of details.
    Take a screenshot of your output module
    Richard M. Harrington, PMP
    Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
