Activity › Forums › Apple Final Cut Pro Legacy › why r my clips importing pixelated in fcp?
Posted by Pedro Prates on July 21, 2009 at 10:09 amhi!
when i import to an fcp sequence these otherwise fine-looking clips in quicktime, they get incredibly pixelated, and export that way too.
the clips are on prores 720p at 30 fps. i am using this set up too for the sequence, but have also tried others without success.
can u see what’s happening? any help is greatly appreciated.
thanks!
Pedro Prates replied 17 years, 2 months ago 5 Members · 15 Replies -
Tom Wolsky
July 21, 2009 at 1:51 pmHow about a screen shot of what you’re seeing? Maybe screen shots of the item properties of the clips and of the sequence would be helpful too.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Chris Tompkins
July 21, 2009 at 2:16 pmWere these clips digitized on ur machine?
Chris Tompkins
Video Atlanta -
Pedro Prates
July 21, 2009 at 2:25 pmhey chris, thk u 4 helping out.
the clips were digitized on my mac with fcp, adjusted in compressor and then worked in color.
but all and all, the problem is that although they look fine and as expected with quicktime, in fcp they open up pixelated.
i will post samples asap, so that it gets clearer.
cheers
John Fishback
July 21, 2009 at 4:29 pmHow are you monitoring?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Kevin Monahan
July 21, 2009 at 6:53 pmRight. Appears that Peter is not monitoring with an external video monitor. Peter, what happens when you stretch out your Canvas so that it is 100% size precisely??
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Pedro Prates
July 21, 2009 at 8:02 pmhey john hey kevin,
the problem persists on an export from fcp regardless of monitoring… if i open the clip using fcp as a simple player the problem is the same, whereas opening this clip with quicktime or color shows it fine! asap will post screens caps, maybe clearer then. thx!
Tom Wolsky
July 21, 2009 at 8:08 pmYou slipped in a little information here that maybe needs more detail
“the clips were digitized on my mac with fcp, adjusted in compressor and then worked in color.”
Please explain exactly what your process was, what the original specifications were, exactly what you did in Compressor, and exactly what sequence specification you’re editing in FCP. Give as precise and complete information of everything that’s gone on here because it’s possible something went very wrong in this process.
All the best,
Tom
Pedro Prates
July 21, 2009 at 8:14 pmhey tom, will do that asap, but how could the clip play fine everywhere but in fcp? what mistake could explain this?thx, cheers!
Kevin Monahan
July 21, 2009 at 8:35 pmAs I said, try setting your Canvas to 100% and see how it looks. It’s a very common problem.
Kevin Monahan
