Activity › Forums › Apple Final Cut Pro Legacy › why r my clips importing pixelated in fcp?
  • Tom Wolsky
    July 21, 2009 at 8:44 pm
    If you play a 320×240 Cinepak AVI at 15fps it will look great in the QuickTime player. if you play it in an HD FCP sequence not so much any more.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Pedro Prates
    July 22, 2009 at 9:32 pm
    hey tom, chris, john and kevin. thank u all for your feedback. the tip about monitoring and quicktime nicely showing otherwise poor footage in fcp was key.
    i used compressor to blow up a regular dv import to 720p resolution. it looked good enough in quicktime to be used for this job, so i just retouched it in color to make a good base track. only in fcp did this turn sour.
    i need to turn in 720p, and this colleague had an older footage of exactly what i was in need of. this meant i didn’t have to go on the field to get new footage… i am kind of hoping this can still be solved, do you think it’s possible?
    how can i make my footage look as good in fcp as it does in quicktime?
    it’s on prores, 720p. is there any setting in fcp that can make this happen?
    or any way to recompress the initial dv to make this work?
    cheers,
    p.p
  • John Fishback
    July 22, 2009 at 10:09 pm
    When you upscaled in Compressor, did you have Frame Controls on (in the Frame Controls tab of the Inspector) and the Resize Filter set to Best? If not, try that on a short clip to see if it helps. It should improve the scaling of the clip.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Pedro Prates
    July 24, 2009 at 1:00 pm
    hey!
    tried all sorts of different combinations, didn’t know about the frame controls, thanks. it seems like the differences still aren’t enough though, it still looks pixelated. here’s a screen cap of the three best candidates.
    is there a way for me to get the quicktime quality in fcp? if it’s not to much to ask, can you please explain why fcp can’t show the same quality as quicktime?
    cheers,
    p.p
  • Pedro Prates
    July 24, 2009 at 10:33 pm
    hey, i hope u still see this, cause i have a big question on something i found… on an earlier draft i had an acceptable outcome, and the only difference i notice is that instead of prores i used the aic by mistake… isn’t this supposed to be an obsolete codec? how can i choose my settings in prores to make it look like the aic convert? is this possible, or even interesting? should i stick with aic? thank u for your time with all of this, here is a cap of the two clips side by side in image and numbers.
    a href=’https://i1.creativecow.net/u/132522/picture3.jpg’>
Page 2 of 2
