Activity Forums Adobe Premiere Pro why no ram preview in PP cs 6.03?
  • why no ram preview in PP cs 6.03?
    Posted by Dylan Mann on December 14, 2012 at 8:11 am
    As above. I’m relatively new to PP, so pardon me if I forgot some settings and stuff.
    I searched over the net, and it seems that Ram preview is only available in AE, is that true?
    i asked this because i’m having some odd problems here :
    video source : canon 550d video (h264 720p @24fps)
    added effect : neat video reduce noise
    once i added and applied the effect, the bar becomes red and i am unable to preview my clips in real-time. it stutters like crazy and i have to Render entire work area before I can preview it normally (where rendering took around 40minutes for a 2min clip?!)
    note that it continues to stutter even though i’ve previewed the whole clip thrice.
    the CPU usage rammed up for awhile, but went back to idle pretty soon. bar continues to stay red.
    the preview resolution is set @ 1/4.
    my com specs are more than enough to support the video source :
    i5 2500k @ 4.6ghz, 1.40v (overclocked)
    16gb RAM
    GTX560 TI 1Gb (hacked list to support MPE)
    what can i do to make it preview in real-time? please help. thanks!
    Dylan Mann replied 13 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Angelo Lorenzo
    December 14, 2012 at 8:46 am
    Do you have one of the newer versions of neat video? Open the effect, go to preferences and you can benchmark it. It should take advantage of nVidia CUDA processing, otherwise it’s a very heavy effect… but not nearly enough as to have a 20:1 encoding ratio.
    How is the rendering/playback speed for MPE in software mode?
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Dylan Mann
    December 14, 2012 at 9:30 am
    yes i am using neat video 3.2 (just one version earlier..)
    benchmarked @ 20.8fps.
    MPE in software mode is dog slow! 🙁
  • Dylan Mann
    December 14, 2012 at 10:14 am
    [img]https://i.imgur.com/yDalI.png%5B/img%5D
    update : even after rendering entire work area (and bar turns green), clips still stutter (notice the purple lines at 2nd clip onwards)
    what did i do wrongly?
    on a side note : if the noise profiles for most of the clips i need are the same, how do i apply them to all those clips effortlessly without doing profiling again? drag-and-dropping doesn’t seem to work – i need to do reprofiling.
  • Ann Bens
    December 14, 2012 at 1:02 pm
    Purple line means an effect has been added (when a clip is selected in the timeline the purple line goes green)
    If after rendering still no good playback you should check your machine.
    Overclocking is not always a good thing, not enough hard disks etc.
    For applying the same effect:
    Add effect to clip and adjust
    Go to timeline and select that clip and copy
    Select all other clips, right click and Paste Attributes.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Dylan Mann
    December 14, 2012 at 1:04 pm
    sorry, but even with default settings (no OC) and 1TB of free disk space, i am encountering this same issue. what should i do then?
  • Jeff Pulera
    December 14, 2012 at 4:15 pm
    Hi Dylan,
    Noise reduction plugins take forever to render, this is normal. What I do is use After Effects and apply noise reduction (Red Giant Denoiser II in my case) to the raw clip and export to a new file, then Import that new, clean clip into Premiere and then there is no lag during editing and I can add other effects and such in realtime again. That way the noise reduction is not dogging the system while I am editing.
    Here’s some info regarding the render bar colors in Premiere that may help explain the how and why of what you are seeing – https://blogs.adobe.com/premierepro/2011/02/red-yellow-and-green-render-bars.html
    Jeff Pulera
    Safe Harbor Computers
  • Dylan Mann
    December 15, 2012 at 9:16 am
    but isn’t your Red giant denoiser a plugin as well? what’s the difference? i remember running neat video last time before (on a less-able rig), but i don’t recall it being THIS slow.
