Activity Forums VEGAS Pro why no playback….?
  • Mike Kujbida
    August 4, 2011 at 7:03 pm
    [Earle Del Rosario] “In DVD Architect 2.0, the saved project can be opened and played back(with its subtitles) from the timeline. But, after I burn it, I play it back on the DVD set-top player, and there are no subtitles.”
    Is the subtitle feature for your set top player enabled?
  • Earle Del rosario
    August 5, 2011 at 4:21 am
    i’ll check on that.
  • Earle Del rosario
    August 5, 2011 at 7:59 am
    subtitle on set-top is on, but still no subtitle from burned DVD.
    The subtitles are seen when the file is played from timeline on Architect2. That is what is on the timeline when I click “Make DVD.”
    Could there be another step for the subtitles to be recognized?
  • Mike Thomas ii
    August 11, 2011 at 1:36 pm
    On the main screen check to see if the subtitle track is active (activate track), and choose ‘english 1’ as the track language.
    In the project properties, under Initial subtitle track, select 1.
    You can also try a different brand of DVD media, and check if there are any driver/firmware updates for your burner.
  • Earle Del rosario
    August 12, 2011 at 2:04 pm
    Where is the project properties that has “initial subtitle track” ?
  • Mike Kujbida
    August 12, 2011 at 10:35 pm
    [Earle Del Rosario] “Where is the project properties that has “initial subtitle track” ?”
    Look under File – Properties.
Page 2 of 2
