Activity › Forums › Adobe After Effects › Why my rendered 10 seconded 500×300 pixel (avi) 116MB? how do i make it smaller?
Posted by Electricsashimi on February 3, 2007 at 8:00 pmWhy my rendered 10 seconded 500×300 pixel (avi) 116MB? how do i make it smaller?
Dommafia replied 19 years, 7 months ago 4 Members · 6 Replies -
Brian Charles
February 3, 2007 at 8:18 pmWhat compression did you use? Try another one. I
generally output to QuickTime rather than avi.
The Animation codec will produce the largest file size since it is uncompressed. The compression scheme you select depends on the destination for your file.
If you want a small file size and high fidelity H264 is your best choice. Be aware that any compression can introduce artifacts and color shifts.
Electricsashimi
February 3, 2007 at 10:15 pmHow do i compress the video when I render in after effects?
Steve Roberts
February 3, 2007 at 11:01 pmUse the render queue and pick a codec in the output module. Check the manual.
Dommafia
February 5, 2007 at 7:11 pmThere’s a great FREE utility that let’s you compress your audio and video to whatever settings you’d like. The way i use it is:
1. Make my render in after effects lossless (big size, high quality)
2. Open my render in Virtuadub and save new copies of it at different compression ratios for the video and audio.
3. Decide which settings gives the best compression to quality ratio and delete the other copies.I hope this helps.
VirtualDub: https://www.virtualdub.org/download
Electricsashimi
February 6, 2007 at 2:20 amThx for helping me out, but i used a video converter and converted the avi to avi. Turns out that the 116mb turned to 3 mb. Wow!!
I couldn’t see any change in the quality.
Hope this helps other people having this problem
Dommafia
February 6, 2007 at 11:28 amThat’s what virtualdub is, a video and audio converter. I’m glad you found a solution 😀
