Activity › Forums › Adobe After Effects › Why is there suddenly a default filename for my AE renders?
  • Why is there suddenly a default filename for my AE renders?
    Posted by Mike Mackenzie on June 28, 2013 at 6:26 pm
    Adding to render queue now creates a file with the output name “06.mov.” I have no idea why this is, and it is very inconvenient. I’m sure it’s a simple fix, but I don’t know what that is. Tried rebooting, tried switching to a different project, no luck. Any help is greatly appreciated!
    Motion Graphics Designer / Art Director
    Boston, MA
    System:
    Mountain Lion on SSD
    2 x 2.8 GHz Quad-Core Intel Xeon
    NVIDIA Quadro FX 4800
    18 GB RAM
    Mike Mackenzie replied 13 years, 3 months ago 3 Members · 4 Replies
  • Cassius Marques
    June 28, 2013 at 6:55 pm
    By default it should be your “comp’s name”.”last format used”. Isn’t 06 your composition’s name? If previously it asked for the output name, there’s an option for that. You should check the preferences.
    Other than that. I don’t know. What do you mean it “creates” a file? Where?
  • Mike Mackenzie
    June 28, 2013 at 7:54 pm
    06 was not the comps name, and by creates file, I mean in the render queue, the file to be rendered does not have the comps name, instead it is called “06.mov.” Eventually solved by changing render-to location, but I still have no idea what happened.
    Boston, MA
    System:
    18 GB RAM
  • Doyle Lewis
    June 28, 2013 at 8:28 pm
    Is your naming template set to current frame?
    Doyle Lewis, Assistant Videographer
    thinkck.com
  • Mike Mackenzie
    June 28, 2013 at 9:37 pm
    I am unfamiliar with that function, so I will answer “probably.”
    Boston, MA
    System:
    18 GB RAM
