Activity Forums Adobe Premiere Pro Why is there so much difference in video colors and quality when playing the same video on VLC media player and playing it on YouTube
  • Why is there so much difference in video colors and quality when playing the same video on VLC media player and playing it on YouTube
    Posted by Mohd Faizan on July 23, 2017 at 7:45 am
    I have encoded a video in Adobe Premiere Pro at 1080p and uploaded on youtube, but it looks very different on youtube what it looks like on my PC VLC media player.
    System Configuration
    i7 6700K
    16 Gb ram DDR3
    Nvidia Quadro K2200
    Mohd Faizan replied 9 years, 2 months ago 3 Members · 3 Replies
  • Duke Sweden
    July 24, 2017 at 12:18 pm
    Does it look different in VLC than it does in Premiere Pro’s program window as well? If you open the encoded file in Premiere Pro and it matches the original post video, then go to preferences (or tools, I forget which) and go to the video section. There’s a dropdown list there. Choose “Use Open GL” (NOT “Use Open GL experimental”) and that will fix the problem.
    If your video looks the same in VLC as it does in Premiere Pro, then it’s a youtube thang. In which case are you encoding using a youtube preset? If not, do so.
  • Marc Nibor
    July 24, 2017 at 12:29 pm
    It’s your Nvidia Drivers settings and it’s a known issue.
    You can fix that Problem by opening “NVIDIA Control Panel”
    then go to > Video > Adjust video color settings
    on the right side under “How do you make color adjustments? make sure “With the NVIDIA settings” is active
    go to the advanced tab and choose Full (0-255) That’s it.
  • Mohd Faizan
    July 24, 2017 at 1:20 pm
    Thanks.
    Video inside Premiere Pro and on Youtube looks same.
    But different on VLC.
    Actually, the problem was due to the graphic card,
    Changed Output Dynamic Range, Limited to Full.
