Activity Forums Adobe Premiere Pro Why is there a thin black stroke around .png images in Premiere / Encoder exported videos?
  • Why is there a thin black stroke around .png images in Premiere / Encoder exported videos?
    Posted by Eric Mccarthy on June 27, 2013 at 4:29 pm
    I have a thin grey stroke that is showing up around all the image .pngs in my output files. The stroke doesn’t show up when the video is viewed in Premiere. I am using .png files to cover specific parts of the video track, and I want them to blend into the background (it is a screen capture with some info that needs to be covered up).
    I cross posted this on an existing thread in the Adobe Community forum. Someone else has the same issue. Here is a link to that forum, which includes screen shots:
    https://forums.adobe.com/message/5427456
    Any help would be great.
    Thanks in advance.
    -Eric
    Chris Borjis replied 13 years, 2 months ago 3 Members · 9 Replies
  • 9 Replies
  • Ivan Myles
    June 27, 2013 at 6:51 pm
    Try trimming the edges with the Crop effect.
  • Eric Mccarthy
    June 27, 2013 at 7:09 pm
    Okay, I am going to try this and send an export to the Queue. Will let you know what happens.
  • Ivan Myles
    June 27, 2013 at 7:18 pm
    I recommend using a direct export from Premiere instead of the AME queue.
  • Eric Mccarthy
    June 27, 2013 at 8:17 pm
    I used the Crop Tool on the PSD file before exporting a .png, then replaced the .png in the Premiere timeline, and viola! It worked. Not sure why… but I will take it!
    I encoded using AME and it still did okay, just out of curiosity, why did you recommend against AME? I use this all the time…
    You can see a more detailed discussion of this issue (border around .pngs) on this thread at Adobe Communities.
    https://forums.adobe.com/message/5456455#5456455
  • Ivan Myles
    June 27, 2013 at 8:26 pm
    [Eric McCarthy] “just out of curiosity, why did you recommend against AME? I use this all the time…”
    It helps with troubleshooting to eliminate potential contributing factors. In addition, if the output is being rescaled upon export then sending a job to the AME queue can degrade image quality, as discussed in this post.
  • Chris Borjis
    June 27, 2013 at 8:48 pm
    also sending it to que typically adds A LOT more export time.
    I had a video that exported directly out of premiere took 15 minutes.
    that same sequence exported through the queuing in ame wanted an hour!
  • Ivan Myles
    June 27, 2013 at 9:26 pm
    Sometimes the queue is slower and sometimes it is faster. In a test of 40 rendering jobs it was 30 seconds slower on average. When transcoding from a master file the queue was 2.4 minutes slower per file. The main advantages are background processing and the ability to queue multiple jobs in succession.
  • Eric Mccarthy
    June 27, 2013 at 9:55 pm
    Thanks guys,
    I am always ping-pong-ing back and forth between projects, so I have to use the AME to keep Premiere open for work. Sometimes, if I am also doing AE work I will set the AME up on a separate machine (accessing the timelines from our RAID), but I am usually more concerned with the processor hit to the current program working than to the encoding process in the BG… Still good info to be aware of.
    -Eric
  • Chris Borjis
    June 27, 2013 at 10:53 pm
    I hear that.
    If I have a bunch of sequences to get exported and have time or
    running overnight I do que them.
    Exporting H.264 takes WAY longer though compared to codecs like ProRes
    via que in my experience.
