Activity Forums Apple Final Cut Pro Legacy Why is the beginning of my video a jerkathon?
  • Why is the beginning of my video a jerkathon?
    Posted by Roli Rivelino on November 2, 2011 at 6:02 pm
    I shot a couple of conference videos at 720pn and then edited them on a 1080i timeline, using a DVC pro 72050 compressor.
    Everything was fine until I got together a highlights video at the beginning of the video I’ve done a simple motion effect whereby the clip slides onto the screen from right to left and then is followed by a couple of slide transitions, again sliding from right to left.
    The problem is these effects have turned into a complete jerkathon and are no longer smooth, everything is fine until export, I’m currently trying different export settings but so far to no avail.
    My original compressor settings are ones that I always use for 720 web videos they are as follows: size 1280 x 720 bit rate 5000 kbs frame rate 50 fps, key frames every 30.
    I then tried a deinterlace wherby everything is as above, except the bit rate is 3500 and it’s got a deinterlace filter on it.
    Here is the video you only have to view the first 30 seconds or so to see what I’m talking about. here
    Any help or comments would be much appreciated.
    Many thanks.
    https://www.rolirivelino.com/
    System
    Mac Pro 2.8Gb quad core
    8Gb RAM
    1x 320Gb 7200 hardrive
    1x 1Tb 7200 hardrive
    Nvidia Geforce 8800 512mb Graphics card
    1x 1Tb external WD ‘My Book’ eSata
    Equipment
    Panasonic AG-HVX 200
    Firestore FS-100
    Roli Rivelino replied 14 years, 10 months ago 4 Members · 5 Replies
  • Mr Smith
    November 2, 2011 at 6:41 pm
    I would turn the bit rate down <2000, plays fine off the web. Also your first effect, the slide doesn’t push all the way to the edge.
  • Bret Williams
    November 2, 2011 at 7:40 pm
    Put the keyframes on automatic and instead of bit rate put the slider somewhere just above medium. Maybe the first tick above medium.
  • Roli Rivelino
    November 2, 2011 at 9:26 pm
    Mr Smith, dropping the bit rate to under 2000 didn’t work, I’m trying some other things, I’ll try putting on auto and the slider to medium.
    System
    8Gb RAM
    Equipment
    Firestore FS-100
  • Chris Tompkins
    November 2, 2011 at 10:29 pm
    Why are you putting 720 clips in a 1080 sequence and then selecting a 720 compressor?
    This makes no sense.
    Chris Tompkins
    Video Atlanta LLC
  • Roli Rivelino
    November 3, 2011 at 9:41 am
    I did it because the first clip I laid down was the 1080 stinger, I was being lazy essentially!
    However I redid the sequence in 720 and did a 720 compression and it made no difference whatsoever.
    Any ideas?
    System
    8Gb RAM
    Equipment
    Firestore FS-100
