Activity › Forums › Adobe Premiere Pro › Why is Ripple Delete blocked?
  • Why is Ripple Delete blocked?
    Posted by Angelo Lorenzo on December 26, 2012 at 10:54 pm
    I have a track of video and three tracks of audio. Track 3 of audio is background music, so I’ve disabled sync lock.
    I usually ignore these issues, but I’ve been trying to cut with more of an Avid style (more lifts, extracts, using the trim monitor more), so why is Track 3 of audio blocking my ripple delete if sync lock is disabled for the track?
    I created the gap by selecting an in and out on the timeline and using extract(‘). Cutting gaps with the razor tool leads to the same issue. Normal trim edits seem to work with sync lock as I assume it would. The gap aspect seem to be the most upsetting to the procedure.
    Oddly, if I butt up track 3 of audio to the start of the timeline, ripple delete is unblocked.
    Is my mode of thinking incorrect somewhere?
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Angelo Lorenzo replied 13 years, 9 months ago 1 Member · 1 Reply
